Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Set of 5
Old 08-25-2016, 07:04 AM   #1
Default Set of 5
Is there anywhere to buy a 5 piece set of wheels and tires? I want bead locks with rock beast tires in 1.9 but is the only option to buy 4 or 6?
Sent from my XT1254 using Tapatalk
athens29 is offline   Reply With Quote
Old 08-25-2016, 08:28 AM   #2
"GOD SPEED"
Default Re: Set of 5
Tires I believe you will have to buy 6 and sell the spare but vp will sell a single wheel, you just have to order 2 and in your notes put that you only want 1 and they will issue a refund for the 2nd one. Not sure with other companies, some do sell spares.
nerby149 is offline   Reply With Quote
Old 08-25-2016, 08:33 AM   #3
R2j
SORRCA Committee Member
R2j's Avatar
LockedUp RC sells wheels by each....so 1 or 4 or 11, you see where I'm going with that.
http://lockeduprc.com/
R2j is offline   Reply With Quote
Old 08-25-2016, 09:18 AM   #4
GearHead sells singles also...........
Pretty sure RC4WD does also.......
roksloski is offline   Reply With Quote
Old 08-25-2016, 10:43 AM   #5
GCM Racing also sells their wheels individually.
Alexander_0_1 is offline   Reply With Quote
Old 08-25-2016, 11:51 AM   #6
Rockbeasts, no, unless you go in with someone else on a pair.
Wheels, yes, the above mentioned and rc4wd sells single wheels.
Szczerba is offline   Reply With Quote
