Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Wheels with axial 1.9 6 bolt beadlock pattern?
Old 03-28-2017, 02:31 PM   #1
Default Wheels with axial 1.9 6 bolt beadlock pattern?
Looking for wheels that have the axial1.9 6 bolt beadlock pattern, I'm over the integy wheels I have and would like to find some wheels that The locked up rc 1.9 wheel widerners will work with. On Their site they say they kit works with wheels that use the axial beadlock bolt pattern. Other than axial, what wheels use that pattern.
Thanks
Sent from my SAMSUNG-SM-G900A using Tapatalk
Grandbuggy is offline   Reply With Quote
Old 03-28-2017, 03:44 PM   #2
No idea what I'm doing
Default Re: Wheels with axial 1.9 6 bolt beadlock pattern?
Why not look for wheels in the width you want?
Limiting your options to only wheels that work with those particular wideners kind of restricts your choices.
C*H*U*D is offline   Reply With Quote
Old 03-28-2017, 04:01 PM   #3
I have been, i can't find anything 1.5" wide. I rather have wheels are the proper width but I just haven't had any luck finding them. If I could find some that wide that I liked I'd jump on it
Old 03-28-2017, 05:37 PM   #4
I would buy lockeduprc wheels to go with those widener's
littletoyboy is offline   Reply With Quote
Old 03-28-2017, 08:54 PM   #5
I'd like to but the price is killer for my budget
Old 03-30-2017, 11:47 AM   #6
Vaterra beadlocks (VTR43000) have the same beadlock "bolt" pattern as Axial. You can usually find a set of four for under $30.00. Hope this helps!
JohnB is offline   Reply With Quote
Old 03-30-2017, 01:02 PM   #7
SCALE PERFORMANCE PARTS
Locked Up's Avatar
What is your budget?
Our most affordable 1.9" wheels are our 8L wheels because there is no axle flange or hex hub required.
They bolt on to your 12mm hex just like a stock wheel which saves some cash.
We have some 1.9" 8L Rock Cutters on sale right now as well:
1.9" Rock Cutter 8L Beadlock Wheel
Our cheapest outer rings at the moment are our Agile 2 tone, which are available in 4 colors:
1.9 Rings
Slap in some MCZ cap screws and for ~$85 you got a great set of scale wheels with some color that are made in the USA that ship to you right from Texas.
Locked Up is offline   Reply With Quote
Wheels with axial 1.9 6 bolt beadlock pattern? - Similar Threads
Axial ax10 2.2 beadlock pattern? Goatsniper Tools, and Procedures 4 06-03-2014 01:06 PM
proline 8 shooter ring bolt pattern? idk Tires and Wheels 0 05-24-2013 01:59 PM
bolt pattern for ax10 and wraith trannie Oregon crawler Axial Wraith 1 03-28-2013 02:30 AM
bolt pattern? 27cameron Axial AX-10 Scorpion 3 08-12-2009 11:02 AM
ford wheel bolt pattern wheelspinner Chit Chat 5 08-03-2007 08:39 AM
