Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Good set of 2.2 wheels with a lot of off set?
Old 04-08-2017, 09:02 AM   #1
Default Good set of 2.2 wheels with a lot of off set?
I have an ax10 and the wheels are hitting the shocks. I have stock axles and stearing and would like to up grade and better staring but am already hitting the shocks with the wheels. So was hoping to get a wheel with a good off set to fix it?
Sent from my A1601 using Tapatalk
nurgs is offline   Reply With Quote
Old 04-08-2017, 12:00 PM   #2
Default Re: Good set of 2.2 wheels with a lot of off set?
I would look into the XR10 mod if you're running 2.2's as it will widen your axles a bit and provide tons of steering. If you run wide wheels you'll just have lots of scrub and the wider offset will be harder on your axles.
But to answer your question directly, if you want a good set of cheap wheels check out the CI 6-bolt wheels. You can run vanquish hubs to get any offset you want from super narrow to crazy wide and they come in 1" and 1.5" widths.
https://www.tcscrawlers.com/Crawler-...p/dd6b2.2w.htm
Highmark is offline   Reply With Quote
Old 04-08-2017, 02:24 PM   #3
OK thanks for the help xr MOD it will prob be
