04-27-2017, 12:33 PM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: right here!
| Suggestions on foams for tsl swamper xl
Any suggestions on what foams to use for proline super swamper xl? I used c.i foams but for some strange reason it feels like there a space on the sidewall. I'm using the 4.75 standard inner and soft outer. Any suggestions greatly appreciated. Thanks. Sent from my SAMSUNG-SM-G900A using Tapatalk |
04-27-2017, 01:07 PM | #2 |
| Re: Suggestions on foams for tsl swamper xl
If I remember DW single stage tall(6") and a set of tuning rings per pair(2 sets) That's what Eddie told me and sold me, they work, but the rings are a tight fit ! Hang up and Drive |
04-27-2017, 01:12 PM | #3 | |
| Re: Suggestions on foams for tsl swamper xl Quote:
Sent from my SAMSUNG-SM-G900A using Tapatalk | |
04-27-2017, 01:38 PM | #4 |
BIG difference I'm a 2.2 guy. Go to the CI website and send a message to Eddie. He will tell you what has worked the best, as a great starting spot. Hang up and Drive |
04-27-2017, 03:01 PM | #5 |
RCC Addict Join Date: Sep 2014 Location: Alberta
They make a Deuces Wild specific to that tire. DW will have space between the foam and the tire itself, by design. Vent the tires: three 2mm holes in the center of the tread, NOT the sidewall. DW is waterproof and work great on a bit heavier rig. If you want two stage foams (Lil' Nova), give Eddy a call with details on your rig, mainly weight and intended use, and he will recommend you the right set. |
04-27-2017, 04:37 PM | #6 |
Rock Crawler Join Date: Nov 2014 Location: Dells
The proline 2 stage foams work great too.
04-27-2017, 04:40 PM | #7 | |
04-27-2017, 04:41 PM | #8 |
| Re: Suggestions on foams for tsl swamper xl |
04-27-2017, 05:05 PM | #9 | |
There's a TON of people using the TSL XL tire with the Deuces Wild that was made for it with great success. You want some gap between the tire and closed-cell foam, it lets the tire do all the work and conform to the surface, the foam simply provides support. I've never used tuning rings myself but I have used a smaller tire with foams that were a little big/didn't have any "gap" and they performed horribly for what it's worth. You're essentially relying on the stickiness of the rubber to provide all the traction at that point, not allowing it to conform. Just my $0.02. Sent from my iPhone using Tapatalk | |
04-27-2017, 05:13 PM | #10 | |
04-27-2017, 05:15 PM | #11 | |
I understand. But if the foam is too tight to the sidewall, it doesn't allow the rubber to flex/wrinkle as much which can hurt performance. I definitely prefer the look of a firm sidewall myself and I'm sure it's not THAT different for performance, just wanted to share that most people have that gap, it isn't uncommon. The tuning rings would be the only thing I'd use to fix that problem. Sent from my iPhone using Tapatalk | |
04-27-2017, 05:16 PM | #12 | |
Suggestions on foams for tsl swamper xl - Similar Threads | ||||
1.9 to 1.55 TSL swamper foams | LamChop | Tires and Wheels | 5 | 02-14-2016 08:02 PM |
foams for 1.9 Super Swamper TSL/SX | drzjohn | Tires and Wheels | 1 | 12-19-2010 12:00 PM |
