05-26-2018, 11:00 PM | #1 |
Quarry Creeper Join Date: Mar 2018 Location: Park Hills
| CI DD comp cut front foams rolling over in tire making it to one side?
I'm running CI Double Deuce Comp cut medium 5.5 foams in the front and when crawling front tires are getting all over to one side in what I can describe as the out foam rolling over to one side. What is the remedy to this? Bomber weighs 10 pounds. Tires are Pitbull Growlers. I already ordered a set of Deuces wilds to try in the front just in case it's a normal thing. |
05-27-2018, 01:47 AM | #2 |
Newbie Join Date: Oct 2016 Location: Las Vegas
| Re: CI DD comp cut front foams rolling over in tire making it to one side?
you could try use some hair spray between the two layers of foam. it sets up quick and will prevent the top layer of foam from sliding off the inner.
05-27-2018, 06:46 AM | #3 |
RCC Addict Join Date: Jun 2017 Location: Canada
What is the size of the tire? Eddie always recommended foams bigger than the tire. A pain to get in but it can't move easily. My stock bomber kit tires are 5.43 with 5.5 foams and my MT/R are 5.63 with 6.0 foams (thin outer layer removed). Also did you punch holes in your tires so they actually work with double deuce? Sent from my Nexus 6 using Tapatalk |
05-27-2018, 08:56 AM | #4 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
Are your inner foams comp cut. Comp cut inner foams are suppose to help with that problem.
05-27-2018, 12:51 PM | #5 |
Yeah my tires are vented and yes comp cut. The tires are 5.5 tall overall more like 5.25 internal and foams are 5.5. The foams where definitely bigger than the tires and a pain to get in. |
05-27-2018, 01:04 PM | #6 |
In some cases the foams slide on the wheel or ring. Adding some type of grip material can help. Sent from my XT1650 using Tapatalk |
05-27-2018, 01:14 PM | #7 |
| Re: CI DD comp cut front foams rolling over in tire making it to one side? |
05-28-2018, 12:38 AM | #8 |
05-29-2018, 08:35 PM | #9 |
Slipping foams is why I have started cutting traction grooves on my wheel rings. |
05-30-2018, 01:53 PM | #10 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
What wheel are you using and how wide is it? What voltage are you using? What is the intended usage/ terrain? |
CI DD comp cut front foams rolling over in tire making it to one side? - Similar Threads | ||||
Should I cut rear tires foams also, or just front? | joshuatest | Newbie General | 8 | 01-18-2011 08:25 PM |
