Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: New SSD 6mm Offset Rotor Hubs
Old 11-29-2017, 03:03 AM   #1
SSD
Default New SSD 6mm Offset Rotor Hubs
6mm Offset Wheel Hub with Brake Rotor
SSD is offline   Reply With Quote
Old 01-05-2018, 01:02 AM   #2
Default Re: New SSD 6mm Offset Rotor Hubs
I'm looking to narrow up my track width on a car that currently has .350 SLW hubs, and I'm digging your rotor/hubs . How do these compare to SLW hubs? If I'm interpreting the drawings on your site correctly, SSD00192 would be slightly narrower than a .225 hub, the "3mm offset" SSD00194 would be close to a .350 hub, and the "6mm offset" SSD00231 would be close to a .475 hub... is that correct? Please set me straight so I can get some rotor/hubs ordered. Thanks!
TheLetterJ is offline   Reply With Quote
Old 01-05-2018, 03:43 AM   #3
SSD
Yes that sounds about right to me.
Old 01-05-2018, 05:13 AM   #4
Sound great this SSD00192 is narrow than SLW .225 hubs, but are they SSD00192 compatible with SSD HEAVY BRASS KNUCKLES FOR SCX10 II / PRO44 AXLE.?
Teng is offline   Reply With Quote
Old 01-05-2018, 05:15 AM   #5
SSD
All of our rotor hubs are compatible with all of our knuckles and current weights.
Old 01-05-2018, 12:24 PM   #6
Thank you, I'll be ordering a couple pairs for my 1.9 Wraith (though they're HUGE 1.9"s, it's still on AR60's.) Your zero offset rotor/hubs along with 4.5mm thick "narrow" hexes should have my wheels pulled in as close as possible without hitting the draglink, keeping my diffs/tubes from dragging in the rocks so much.
P.S. I've got to compliment you on all the products that you've brought to market in the last couple years. It seems like as soon as I've got an idea in my head, you've got something in the works for me. I'm not usually one to pre-order things since I don't like being the guinea pig, but I've done so with confidence with many of your products and have been delighted with every one of them. Keep up the good work!
Old 01-05-2018, 12:27 PM   #7
Your making some cool stuff.
Ditchrat is offline   Reply With Quote
Old 01-05-2018, 12:29 PM   #8
Hmm, 3mm or 6mm offset for the TRX-4? Any pics of how it'd look?
tuanies is offline   Reply With Quote
Old 01-05-2018, 02:58 PM   #9
SSD rocks! I'm addicted to the brand
Sent from my SM-G930F using Tapatalk
tjohanne is offline   Reply With Quote
Old 01-06-2018, 12:57 AM   #10
Thank you ( SSD ) my SSD HEAVY BRASS KNUCKLES FOR SCX10 II and SSD C-hubs are on the way now.
Old 01-25-2018, 01:09 PM   #11
I received my hubs this morning, they look great, and are exactly what the Dr. ordered for my application. My tire's sidewall is now exactly one gnat's ass away from my draglink end, couldn't have fit any better! Thanks again!
Old 01-25-2018, 01:52 PM   #12
Just installed mine last night. They’re awesome and are just noticeable enough on a 2.2. I’m hoping the extra offset helps keep my Bomber a little more stable!
LSXGMC is offline   Reply With Quote
New SSD 6mm Offset Rotor Hubs - Similar Threads
GiveAway!!! Custom Anodized Shift Hubs (Adjustable Offset Hubs) By Lattice Innovation BC-Brian General Crawlers 116 05-17-2014 08:24 AM
GiveAway!!! Custom Anodized Shift Hubs (Adjustable Offset Hubs) By Lattice Innovation BC-Brian General Crawlers 126 02-14-2014 01:03 AM
Proline Blazer on CC01 chassis-0mm or 6mm offset wheels? Sasquatchbagger Tires and Wheels 2 05-02-2008 01:00 AM
