01-18-2019, 11:07 AM | #1 |
Newbie Join Date: Mar 2018 Location: Crittenden
| Which foams for proline boggers?
Wanting lil nova foams, but don’t see a size for proline boggers. What does everyone use for these tires?
01-18-2019, 11:36 AM | #2 |
Quarry Creeper Join Date: Jul 2013 Location: PA
| Re: Which foams for proline boggers?
I ended up running them on 2.2 wheels with CWR-3005 for the inner and Double Deuce part no. CWR-1087 for the outer.... I tries a few different combo's with 1.9's best I could do was Pitbull Dirty Richards 4.00" stiffies, and a Random CI 2.2 outer... |
01-18-2019, 11:44 AM | #3 |
I used some 1.9" Deuces Wild foams that I had laying around (meant for the Pitbull Mad Beast) and cut a ring of the included Proline foam as the outer, as well as a single tuning disc (also already had) to make up for the width. I bet if you email Crawler Innovations, he can come up with a better setup, but I've been pleased with the way mine have been working.
01-18-2019, 12:43 PM | #4 | |
RCC Addict Join Date: Sep 2017 Location: The OC
| Re: Which foams for proline boggers? Quote:
I had to look up that tire - it's HUGE!! 5.4" Diameter and 1.9" wide. Are you already running them with the stock foams? You want them to perform differently in some way? For actual rock crawling CI recommends the comp-cut inner with a diameter to fit your tire diameter, and an outer that reflects your rig weight. That said, for that tire, their biggest Lil' Nova is 4.75". I would ping them and ask, or post on NovaArk's thread. Not sure if that foam would fill up those tires or not. | |
01-18-2019, 05:06 PM | #5 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
The bogger is a 2.2 size tire for a 1.9 rim. The 5.0" and 5.25" Double Deuce foams fit these tires perfectly. In general, all 1.9 clamp ring style bead locks are using a 2.2 can, so the inner diameter is not usually an issue.
01-18-2019, 05:12 PM | #6 |
| Re: Which foams for proline boggers? Wheels: 2.2 Vanquish Products bead locks Tires: 1.9 Pro-Line TSL Bogger w/ cut lugs Foams: Crawler Innovations Deuce's Wild part no. CWR-3005 for the Inners, Double Deuce part no. CWR-1087 for the Outers The removed lugs from the massive 1.9 Pro-Line TSL Boggers came to 43 grams or 1.5 ounces. #crawlerinnovations #doubledeucefoams #activatedoutlaw |
01-18-2019, 07:01 PM | #7 |
Wow! |
01-19-2019, 09:17 AM | #8 |
| Re: Which foams for proline boggers? |
Which foams for proline boggers? - Similar Threads | ||||
CI double deuce foams in 2.2 boggers | evan03 | Tires and Wheels | 4 | 03-05-2013 07:29 PM |
Stock HB Rover Foams or Proline Memory Foams? | norco kid | Tires and Wheels | 3 | 10-13-2012 11:00 AM |
