Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Wet/dry forest trail threads
Old 02-01-2020, 12:51 PM   #1
Default Wet/dry forest trail threads
Hey people. I have a tire question. I'm running rc4wd superswamper boggers 120mm. Although they work nice on rocky surface, they kind of suck on slippery stuff. Roots, smooth surface.. They have no grip. I have a few options. I can widen the tire by removing the valve screw, and letting all the air out, or buy another tires. I have hyrax (chinese version), but they are on another rig my kid is using, and I have inteco super swampers tsl/sx. Intecos work really well on trails, but not as well as some other types. So I've heard. They are 115mm.
I was thinking of buying this:
https://www.lindinger.at/at/fahrzeug...reifen-crawler
They have a wide thread, and seem grippy. The only issue is that they could limit my steering, since they could hung up on the shock body.
Any other ideas?
It's a trx4 rig, trails are mostly wet/dry forest ground, very few rocks. The rig is at 4kg now, but I'm still waiting for the brass C-hubs and portals, and a warn cti 9.5 winch.. They will add significant weight up front.
Open to any suggestions
Bear in mind that the budget is limited..
ChILd_ReBoRn is offline   Reply With Quote
Old 02-02-2020, 12:43 AM   #2
Default Re: Wet/dry forest trail threads
I always say the Proline Tsl's are the most diverse tire for a trail truck. They don't do anything particularly well, but do well in everything. I was plesantly suprised by Duratrax deep woods my buddy ran. They matched the Tsl's in just about everything.
Vs.
lonleycreeper is offline   Reply With Quote
Old 02-02-2020, 12:55 AM   #3
Vs.
I was just about to click "buy" on the deep woods. The thread looks really nice, and they are higher than my tsl's. (120mm vs 115)...I'll give them a try...
Old 02-02-2020, 09:13 AM   #4
Slow is the new Fast
smog's Avatar
A lot of guys clip their Boggers. Basically removing the shorter lugs (every second lug). It allows the lugs that are left to hook-up better by opening the tread pattern
only cut tires. post up your cut tire photos
smog is offline   Reply With Quote
Old 02-02-2020, 10:17 AM   #5
I've ordered duratrax. Went out today.. My kid had a shitload more grip with chinese hyrax than me with boggers
Old 02-04-2020, 01:29 AM   #6
That looks really good. Impressive build!
mindseye is offline   Reply With Quote
Old 02-04-2020, 02:57 AM   #7
Could have get the "Deep Woods" from Louise tires too ;)....only cheaper.
https://www.lindinger.at/at/fahrzeug...ft-mit-einlage
themountain is offline   Reply With Quote
Old 02-04-2020, 10:10 AM   #8
It's not cheaper.. 34€ for a set of four + 10€ for shipping.. that's 44€. a bit more than 42$ I payed
Old 02-04-2020, 10:30 AM   #9
well bought mine for 36 Euros delivered ...so yes they are cheaper and Iam pretty sure you cant find original Duratrax for that price in Euro.
Old 02-04-2020, 10:58 AM   #10
Moderator
JatoTheRipper's Avatar
Duratrax tires aren't bad, but they aren't quite up to snuff with Proline.
Your terrain sounds similar to around here and I swear by these three tires - Proline Hyrax, Proline TSL XL Super Swampers, and Pitbull Rock Beasts (to a lesser extent since they are a lot more expensive).
Prolines G8 and Predator compounds each have their pros and cons. On damp or wet rocks I'll choose Predator.
Old 02-04-2020, 01:48 PM   #11
for what price? I've bought them off amain hobbies.. if they sell fake tires... I wasn't aware of that...
Old 02-04-2020, 01:56 PM   #12
So basically... super swampers are an OK tire.. but proline version.. Inteco version isn't all that cheap either.. but cheaper than proline. My bead is damaged so I'm not using them anymore. I'll try the canyon tires. They are renowned... and I got a set on 2,2" beadlocks.. so I'll avoid the side flex..
Old 02-04-2020, 02:12 PM   #13
Wet roots are a nightmare for almost any tire.
I feel the TSL SX Super Swamper is decent though.
I hope the Deep Woods work well for you. Be sure to report back once you test 'em out.
rkj__ is offline   Reply With Quote
Old 02-04-2020, 02:18 PM   #14
Originally Posted by hobbyjumper View Post
Valves and compressed air? Do you mean Austar or Gmade, not RC4WD?
The stock Traxxas Canyon Trail tires are a good all-around tire, too.
tires are an original rc4wd. Beadlocks are some ebay rims... but I've drilled them out, tapped them, and I can use the little screw to vent them, or keep them "inflated"
Old 02-04-2020, 02:18 PM   #15
will do!
Old 02-04-2020, 02:29 PM   #16
Moderator
No. Super Swampers are a great tire. In my top three.
Old 02-04-2020, 02:35 PM   #17
awesome...
Old 02-06-2020, 09:37 AM   #18
When you say both wet and dry, I would choose Proline TSL SX XL super swampers any day. I have the G8 compound.
I was rather shocked to see how well they did on snow as well. I run the Proline single stage foam, which is a bit too firm, I think. But they were awesome.
When it comes to Duratrax, I have the Showdowns. They are generally good, but disappointing last time I tried them on wet rock.
tjohanne is offline   Reply With Quote
Old 02-06-2020, 09:55 AM   #19
Ok.. Thanks. Basically tsl's are really good tired
Old 02-06-2020, 10:11 AM   #20
Imo Proline Tsl's in g8 is the most diverse tire out there. It does good in all conditions, but can be beat by other tires that specialize.
Wet/dry forest trail threads - Similar Threads
comp tires for moss and wet/dry rock Kraqa Tires and Wheels 17 05-13-2014 06:04 PM
Trail Finder 2 in the forest Luther.max Videos! 3 08-29-2012 01:59 AM
Mango rd wet trail kenworthit Scale Videos! 11 07-28-2010 05:57 PM
Wondalga wet trail kenworthit Scale Videos! 12 06-03-2010 03:17 AM
Cleaning Your Rig - Wet or Dry? Mad Scientist General Crawlers 14 02-04-2006 09:48 AM
