04-24-2020, 12:11 PM | #1 |
Quarry Creeper Join Date: Nov 2018 Location: Oakley
| Foam suggestions?
I have a mostly stock TRX4 sport(low cog battery tray and shock towers). It weighs 6.9 lbs(possibly with some water in my stock foams) with the battery, ready to go and the weight distribution is near 50:50. I was almost purely rock crawling, although now i am driving in a river flood area that has lots of down’d logs, stream crossings, mud, river rocks, etc. I need new foams since i have soaked the stockers a few times and they seem to be flat. I’ll probably also grab some aluminum wheel, most likely SSD. Does anyone have a recommendation for foams on this truck? Last edited by mass-hole; 04-24-2020 at 12:16 PM. |
04-24-2020, 12:48 PM | #2 |
Quarry Creeper Join Date: Mar 2014 Location: Masshole
| Re: Foam suggestions?
Just bought a set of SSD wheels myself and so far they were the easiest beadlocks to mount Proline tires to. I had a set of RC4WD rims and the Prolines would constantly pop a bead on more than one tire. I have started to use the Proline dual stage foam and it works great. Rig has great support but still soft enough to conform around rocks etc.... You cannot go wrong with SSD and Proline for your wheel / foam setup IMO. https://www.prolineracing.com/insert...am-inserts.asp |
04-24-2020, 01:01 PM | #3 |
I wanna be Dave Join Date: Sep 2019 Location: US
You should also check Crawler Innovations for tire foams. I have both CI & Pro-Line foams...for two vehicles (a Capra, and a Trail King), the CI foams are better, and for the other two (another Capra, and a Baja Rey), the Pro-Line foams are better. ~ More peace, love, laughter & kindness would make the world a MUCH better place |
04-24-2020, 01:08 PM | #4 | |
| Re: Foam suggestions? Quote:
Yeah, i have a set of SSD 2.2” wheels for my rock rey with proline foams and Hyrax. Wasnt sure if i should go with something softer due to how light the truck is. | |
04-24-2020, 05:19 PM | #5 |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
I’ve started running the crawler innovations foams, but only the dense. I get them a little smaller than the tire and leave a little air gap and it’s working really well for me
Foam suggestions? - Similar Threads | ||||
Foam suggestions for 2.2 slingers | jimbiss | Tires and Wheels | 5 | 09-05-2017 07:37 PM |
Hyrax foam suggestions... | rag6 | Vaterra Ascender | 5 | 06-04-2017 08:39 PM |
Foam suggestions for 2.2 pitbull RB2?? | tomvaillencourt | Tires and Wheels | 9 | 10-07-2014 06:26 AM |
Rover Foam Suggestions | losi22 | Tires and Wheels | 6 | 09-13-2012 01:45 PM |
Axials with standard foam Vs Losi with Memory foam - bounce test | Mud Puppy | Tires and Wheels | 3 | 10-24-2010 11:10 AM |
