Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Center caps
Old 04-24-2020, 11:30 PM   #1
Default Center caps
Hey all
got me some RC Lions Aluinum beadlock wheels. Looking for some center caps. Does it have to be specifically for the RC Lions or can I get any center caps and fit them ? If it can be any center caps, whats some decent ones to get? BTW, they're 1.9
Gamer707b is offline   Reply With Quote
Old 04-27-2020, 08:10 AM   #2
Default Re: Center caps
I don't have any experience with RCLions wheels, but from my experience with other wheels, you're probably better off getting RCLions center caps. Especially if you're referring to the caps that bolt into the wheels. The bolt patterns can vary slightly between manufacturers.
Now, if you mean the center caps/scale hubs that replace the M4 wheel nut, as long as it holds the wheel snugly, you could use any. I suggest SSD RC's or GCM Racing scale hubs. RC4WD makes some nice ones, too, but the size varies a little and some may not fit inside the lip on the wheel.
Ironhide13 is offline   Reply With Quote
Old 05-07-2020, 05:01 PM   #3
Thank you
Center caps - Similar Threads
axial center caps micaman Tires and Wheels 5 04-11-2016 07:23 AM
Scale center caps 68_f100 Axial Wraith 1 09-09-2015 08:55 AM
Center caps for GH rims Strgazr27 Tires and Wheels 0 08-16-2014 06:08 PM
Stuck center caps? tomvaillencourt Axial SCX-10 6 01-07-2013 08:43 PM
