01-31-2023, 12:16 PM | #1 |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
| Short tires for a heavy pig
Any suggestions for a sub 4.5" tire to run on a heavy Axial early bronco with portals. I want keep the CG as low as possible and have enough support and grip for a close to 8lb rig.
01-31-2023, 12:38 PM | #2 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: Short tires for a heavy pig
Foams are really going to be the main concern. Pick a tire you like, see what the stock foams do and go from there. Lil Nova makes some good foams. Sent from my iPhone using Tapatalk |
01-31-2023, 01:30 PM | #3 |
any tire should hold 8lbs with out issue but like snl sead foams play a big role in tracton of any tire
01-31-2023, 02:09 PM | #4 |
| Re: Short tires for a heavy pig I guess the foam is the determining factor, but i know some tires just have weak sidewalls and might require a really hard foam that can't conform to the terrain as well.
02-04-2023, 08:00 AM | #5 | |
Newbie Join Date: Nov 2022 Location: US
| Re: Short tires for a heavy pig Quote:
Sent from my SM-N986U1 using Tapatalk | |
02-04-2023, 11:14 AM | #6 | |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
I used a set of Crazy Crawler LaserFoam "WP Magic" in 1.55 for a project. They are pretty stiff but worked pretty decent for my heavy Gen8 AXE project. Being the type of foam they are, you could also cut them even more to soften up the outside, where the tread would be, if needed. https://www.crazy-crawler.de/en/ Last edited by AK KRAWLER; 02-04-2023 at 11:18 AM. | |
02-07-2023, 01:22 PM | #7 |
The crazy foams seems like they would aid in pulling yourself up the rocks. MIght have to give those a shot.
02-08-2023, 11:45 PM | #8 |
Rock Crawler Join Date: Apr 2015 Location: San Marcos
I put the Pro-Line Toyo Open Countrys on my Bronco. I think they measure just under 4.5". I'm running Pro-Line's dual stage foams for 4.75 tires in them. They hold my Bronco up fine, even under side hill conditions. I hate seeing the whole sidewall flop over when sidehilling. |
02-09-2023, 05:24 PM | #9 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
I run Axial Ripsaws on a cinderblock-like TRX-4 Defender, and they're fantastic. They're a little expensive (IMO) but that 4.3" tire seems perfect on the top-heavy portal'd rig. I won't change 'em for anything.
Short tires for a heavy pig - Similar Threads | ||||
Sway bar for a heavy bomber with short arms? | theTman | Axial RR10 Bomber | 17 | 03-29-2017 06:23 AM |
The scale pig with new tires | luxenberg | Scale Videos! | 0 | 07-27-2013 04:21 AM |
My XR-10 is a PIG! How heavy is yours? | 73bronco | Axial XR10 | 96 | 05-30-2012 05:17 AM |
