07-29-2021, 10:31 AM | #1 |
Newbie Join Date: Jul 2021 Location: Bellevue
| Pro line dual stage foam
Anyone use?
07-29-2021, 12:09 PM | #2 |
Rock Stacker Join Date: Jun 2018 Location: Florida
| Re: Pro line dual stage foam
I have purchased multiple sets, mainly because CI foams were not available. Ive been very happy with them, i have only used them in light to moderate weight trucks 4-6 lbs. i run them in my 7+ pound 6x6, but it has 6 of them and they have done well. unfortunately they only come in soft outer compound.
08-01-2021, 09:23 PM | #3 |
Quarry Creeper Join Date: Jul 2020 Location: Lincoln
Just tried them on my Enduro EXP build. Had them inside of Hyrax Predator tires. Didn’t really see any tire roll to speak of. Sent from my iPhone using Tapatalk |
08-01-2021, 09:32 PM | #4 |
RCC Addict Join Date: Jun 2008 Location: Mudville
Just put a set in a pair of 2.2 Rockbeasts on PL USA Beadlock rims for my Ryft. Not had a chance to run them yet. Still doing some mods on the Ryft. They are A LOT more firm than the soft foam that were in them (unsure what they were)> Considering my Ryft wont see much "ROCK/Stone Crawling" and more Trail Running, Rock Racing, the firmer foams should be quite helpful Not much room for the 2nd stage foam being the RB IIs are 5.5 tall. Filled them out good. but may be a bit too much for anything but Trail running. |
08-03-2021, 02:09 AM | #5 |
Newbie Join Date: Aug 2021 Location: Ardellaborough
In case you weren't aware, there is no air pressure because i punch out 3 very small holes between treads on each tire to let out water and also to keep a consistant footprint without any bouncing around. Psi (of foam) should be the same as stock its just only affecting less than half the volume of the tire OneVanilla Login Last edited by Dwightt; 08-04-2021 at 01:52 AM. |
Pro line dual stage foam - Similar Threads | ||||
Best dual stage foam | jfrye2007 | Tires and Wheels | 2 | 03-18-2021 10:01 AM |
Pro-Line 1.9 Dual Stage Foam | BrianP | Tires and Wheels | 2 | 10-27-2018 05:42 PM |
Dual stage foams ( pro line) | Meir | Tires and Wheels | 2 | 07-27-2017 05:18 PM |
pro-line 2-stage foam and rovers? | Walter95 | Tires and Wheels | 4 | 05-08-2011 12:55 PM |
