03-10-2007, 12:51 PM | #1 |
Newbie Join Date: Jan 2007 Location: Mississauga
| contact cement
Hi, im just wondering if any of you have used contact cement to glue your tires? it seems like it should work good since it has some "rubberyness" to it.. thanks Jakub |
03-11-2007, 02:49 PM | #2 |
i guess ill be the first to try it |
03-11-2007, 03:42 PM | #3 |
Rock Crawler Join Date: Feb 2007 Location: CoMo...Kickin it with Holmes Hobbies
not contact cement, i know that dez is ubsessed with shoegoe and its got a rubbery factor to it.
03-11-2007, 04:27 PM | #4 |
RCC Addict Join Date: Jul 2005 Location: Provo
i used to use it but if your not carefull you'll get it on the sides of your tires and will look like shat;) plus it wont create a very strong seal
03-12-2007, 08:43 PM | #5 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
Ive had really good luck with rubberized CA. It doesnt crack and flake like regular CA. I lay down a bead in the wheel then insert the tire, then roate the tire on the wheel. since the glue takes a few minutes to dry You have time to tweek the way there resting on the wheel if youre not totally happy with it |
03-15-2007, 05:22 PM | #6 |
Quarry Creeper Join Date: Sep 2006 Location: Jackson
Contact cement or rubber cement. Rubber cement stays flexible and rubbery. Contact cement is applied to both surfaces, you let it dry, and when both touch, its stuck permenantly. It's what they glue the laminate on the countertops with.
03-15-2007, 05:46 PM | #7 |
Newbie Join Date: Jan 2005 Location: Frisco, Texas
I've used the rubberized CA with good results also, seems to not flake off the regular or thick CA
03-16-2007, 01:25 AM | #8 |
Newbie Join Date: Feb 2006 Location: hazed from that last one
I 3rd the rubberized CA
