04-28-2007, 10:17 AM | #1 |
Quarry Creeper Join Date: Jun 2006 Location: Folsom
| Poor Mans 2.2 Wheel Mods
I have a cheap method of making standard 2.2 wheels stronger and more functional. First, narrow your wheel if you want. Next, take a wheel and go to the hardware store (I used Lowe's) and get large washers to fit the outside of the wheel and smaller washers to go over the hexes. Use epoxy or some other strong glue to attach them to the wheels. The outer washers are a perfect fit for the 2.2 wheel and will protect the outer bead which is the most vulnerable to damage from rocks. The inner washer will strengthen the hexes and kinda look like disc brake rotors. I have done 3 sets of wheels this way and beat the crap out of them with zero failures. |
04-28-2007, 10:47 AM | #2 |
Quarry Creeper Join Date: Feb 2006 Location: Angier N.C.
That's thinking right there. The thick washers it looks like you used will also help add weight to the wheels, which is always a good thing.
04-28-2007, 10:49 AM | #3 |
I wanna be Dave Join Date: Jan 2004
been doing that in Colorado for years. |
04-28-2007, 03:35 PM | #4 |
RCC Addict Join Date: Feb 2007 Location: MS Coast
Thats also a good way to add a few ounces of weight to each wheel for a lower COG.
04-30-2007, 01:11 PM | #5 |
Rock Stacker Join Date: Feb 2007 Location: jacksonville
dont suppose you have the washer size's do you?
04-30-2007, 02:03 PM | #6 |
Sorry I don't. I just took a wheel over to Lowe's and tried them there. They are almost perfect fits so you will know the correct ones when you try them.
04-30-2007, 02:13 PM | #7 |
Wow, the infamous Dirk Digler....and I didn't even get flamed. :-D This must be the new kinder/gentler DD. |
04-30-2007, 02:29 PM | #8 |
Rock Stacker Join Date: Jun 2004 Location: Fitzgerald, GA
You can also use 1-1/2" x 3/4" reducing washers. Found at any electrical supply house. You can also get them at Lowes and Home Depot seen here on my K2-3L. I just layered them. I painted the washers and layered a set of MSD rock rings on stop. Last edited by LastClodStanding; 04-30-2007 at 02:39 PM. |
