| | #1 |
| Rock Stacker Join Date: Jun 2004
| i have these tires on my dirt demon. they came pre-glued with out foam. http://www2.towerhobbies.com/cgi-bin...LXERS7&P=7 they seem perfect for crawling, well when compared to these that i have on my crawler. http://www2.towerhobbies.com/cgi-bin...XEPB4&P=ML i would like to put the dirt demon tires on my crawler, but im using the stock e-maxx hubs. i believe they are 12mm hex the dirt demons are 19mm hex. since the tires are glued i dont want to take them off even if i did i dont have anything that will fit the tire. so does anyone know a way for me to do this? maybe an adapter? ive tried looking every where but ive had no luck. any help would be appreciated thanks |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: May 2004
| Here you go ya lunatic, Try these, http://www.rcrock.com/shopx/go.cgi?&...g&P=MCT422 Just drill out to suit your axle size and do the grub screw up into one of the holes from the axle pin and your on your way. Simple/ no modification to your max and you can go back to the maxx wheels easily. |
| | #3 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| The maxx hubs are 14mm. You need these for a Twin force.http://www2.towerhobbies.com/cgi-bin...LXGGB9&P=M These will go over the top of your maxx 14mm hex's and get you to 19mm to fit your wheels. |
| Thread Tools | |
| Display Modes | |
