06-27-2007, 01:43 PM | #1 |
RCC Addict Join Date: Dec 2005 Location: Beaver Falls
| what's the easiest way to....
...apply shoe goo to the wheels when mounting tires? I did one wheel with shoe goo for the first time and it made a mess when i was pushing the tire onto the bead. It doesn't help that the shoe goo tube doesn't have a applicator cap like super glue and rtv tubes have so it's hard to apply just a little amount exactly where you want it. I put the tire on the wheel first and then slid the tire bead towards the middle of the wheel while i applied the shoe goo inside the bead of the wheel. When pushing it back over, the sidewall always gets goo all over it. what are your tricks? |
06-27-2007, 02:37 PM | #2 |
Quarry Creeper Join Date: Apr 2006 Location: Pittsburgh
Beadlocks |
06-27-2007, 03:24 PM | #3 |
06-28-2007, 02:56 AM | #4 |
Rock Crawler Join Date: Apr 2006 Location: louisville
what size are the tires someone might back beadlocks for them
06-28-2007, 04:50 AM | #5 |
06-28-2007, 07:04 AM | #6 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
Used CA instead.
06-28-2007, 07:57 AM | #7 |
Quarry Creeper Join Date: Nov 2006 Location: Manchester
The few times that I used shoe goo to mount my tires, I spread it around the bead with a toothpick. Just put some shoe goo onto your wooden toothpick and spread it around the bead. I think I used a few toothpicks per tire if I remember correctly because after a little while they would snap. I ttakes forever to mount up tires this way, but it gets the job done.
06-28-2007, 11:07 AM | #8 |
Rock Crawler Join Date: Apr 2006 Location: pasco,Wa
is there a shortage on ca on the island? seems like alot of trouble and mess when ca works great.Im with ya brother cant afford the beadlocks either,so i use ca.
06-28-2007, 11:55 AM | #9 |
I tried using q-tips (no cotton) but by the time i got all the way around, the glue was starting to get hard. I won't ever use CA glue to mount tires again. Both times i tried to remove them, they tore up the tires pretty bad. I tried the oven trick and boiling them with no luck so no more CA!!!! |
