07-28-2007, 01:15 PM | #1 |
Pebble Pounder Join Date: Jan 2007 Location: Cincinnati OH
| 2.2 molanders
what is the best way to mount a set of 2.2 molanders on erickson beadlocks.....do you have to narrow the 40 series foam......i feel like you cant squeeze the tires together to fit on the rim....any help would be appreciated.. kyle |
07-30-2007, 08:48 AM | #2 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
You may have to narrow the foams some. Go for small increments at a time, it's far easier to remove more material than to add some back. Try this - find a top from a rattlecan, the small ones like Tamiya. Use it as a "base" to set your wheel on as you seat the bead. (anything small enough to fit through the bead but will still support the wheel off your worktable w/o touching the tire) So the backside of the tire hangs free in the air and does'nt push back at you. Then for the other side you can push the tire down and seat the second bead a lot easier than just holding it in your hand or on a tabletop... |
07-30-2007, 04:56 PM | #3 |
RCC Addict Join Date: Sep 2005 Location: Behind the torch!
Get some of Kreepy's squishy foams.!!!!!!!!!!!! The The tall and narrows... You'll love em.! |
07-30-2007, 06:17 PM | #4 | |
I wanna be Dave Join Date: Aug 2004 Location: san jose
is the molanders tire the badlands with maob sidewall | |
07-30-2007, 07:46 PM | #5 |
RCC Addict Join Date: Mar 2006 Location: Bedias, Texas
