08-16-2007, 09:47 PM | #1 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
| Mashers foam: how narrow to cut?
nuf said! got em starred already
08-16-2007, 10:02 PM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
Don't bother cutting them, just buy the Kreepy Squishy Ruby Red inserts. Read the reports on them, you won't be disappointed. If your are determined to use the proline foam, and you've already star cut them, I wouldn't narrow them at all. The star cut takes away most of the integrity of the foam, so you will probably want to keep it full width to give sidewall support for sidehilling. |
08-16-2007, 10:19 PM | #3 |
Ok so I didn't mention it but I already cut em in half. should I just stick both halves in or glue em back together? Yeah I know, woops! oh well live and learn BTW I wanted to add 1 oz in the fronts (already have 3oz in sticky weights on wheel so no more room there)with shot, but won't the foam get in the way? Maybe glue them to the weights? just brainstormin'. Any ideas? Thanks tons in advance! Last edited by solomon7; 08-16-2007 at 10:22 PM. |
08-16-2007, 11:02 PM | #4 |
Pebble Pounder Join Date: Nov 2006 Location: The Land Down Under
+1 on the Kreepy Skwishy inserts
08-16-2007, 11:26 PM | #5 |
I want the Kreepies. Just can't afford them right now;Jeep issues.What about the foams though. Any thoughts?
08-17-2007, 08:27 AM | #6 |
Quarry Creeper Join Date: Jan 2005 Location: Vancouver Island BC... that's Canada eh
I'm in the same boat. Want new foams but the stock ones are all I have right now. And I star-cut them before I was told not to. I did run them full width for awhile but even with 3oz of weight per tire they were pretty stiff. The pic below is with the foams cut to the width of the wheel. This is a close up of it sitting on a cement slab. The tire rolls but I personally like it better than full width. More pics here: CrawlMaster... Mamba... R2... K2-3L... 2.2 Build |
08-17-2007, 08:32 AM | #7 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
Trinity race foam, they are short, give just enough added sidewall support, and let bb's or lead weight roll around well. I did narrow mine a bit too.
08-17-2007, 12:22 PM | #8 |
I actually picked up a paor of trinity med foams on the same trip as you but they seem to be not short enough and too stiff.
08-17-2007, 12:25 PM | #9 |
Quarry Creeper Join Date: Jun 2006 Location: Folsom
They should be roughly the width of the tire carcass when it is on the wheel. I usually mount a tire on a wheel and cut foams to the outer width of the tire. I wouldn't trip about the star pattern now and put in both sides without gluing.
08-17-2007, 01:48 PM | #10 |
If you want to glue the foams back together, get some spray adhesive. It works pretty well. They may be a little stiff at first, but the proline foam is pretty cheap, and will start to break down with use. If you want to run a higher quality foam, such as the Trinity foams, you need to get the ones made for 1:10 scale stadium trucks, such as a XXX-T, or the Associated T-4. That will leave a slight air gap between the foam and the tire. |
08-17-2007, 02:29 PM | #11 |
| do you mean the tread width or very outer edge of tire when viewed from the front of the rig(the sidewall bulge)? It looks like they are already the same width as the tire tread and a hair over. Leave 'em?
08-18-2007, 11:55 AM | #12 |
They sound good to me. I say run them as is. The foam will compress and over time will become softer as they wear in. It sounds like we all will be switching to memory foams in the not too distant future anyway. |
