09-17-2007, 04:18 PM | #1 |
Newbie Join Date: Sep 2007 Location: In the mountains
| How to remove CA glue from tires?
Hi, im new to this forum, obviously... and i managed to strip my 40 series velocitys and fusion welded my hubs to em. So i boiled the wheel, got the tires off, but i cant get the glue off. And i have axial 8 spoke beadlocks ready. What woud i use to get the glue off?
09-17-2007, 04:26 PM | #2 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
Cant get the glue off the tire or wheel? im pretty shure you mean the tire.....what glue did you use to glue them in the first place?
09-17-2007, 04:29 PM | #3 |
Yeah i cant get te glue off the tire. I believe i used zap medium, not sure but im positive.
09-17-2007, 10:53 PM | #4 |
Newbie Join Date: Jun 2006 Location: B_town, CO
Use some acetone (fingernail polish remover), should come right off though it may need to soak a while. The only thing i would worry about is if they are chrome plated, it may damage or remove the chrome.
09-17-2007, 10:58 PM | #5 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
X2 on the acetone CA Debonder is also available at many hobby shops. |
09-20-2007, 08:46 PM | #6 |
Newbie Join Date: Oct 2006 Location: Mammoth
CA glue is the same as Superglue which people use acetone to dissolve
09-21-2007, 12:13 PM | #7 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
X3 on the Acetone. I used acetone over the weekend to dismount and clean up 13 tires. I used a small metal dish that is just a small diameter bigger than the tire. The dish was only 1 inch deep. I sat outside and just took my time. I only soaked one side at a time. I was more concerned with the tires. I did not care about the rims. By soaking one side of the rim & tire at a time, I actually saved some of the foams. If you completely immerse the tire, it will go much faster, but the foam will be completely ruined. The small metal dish is actually a mechanics dish that has a large magnet on the bottom to hold bolts when working on a car. I only filled the dish once, as to not waste the acetone. I also had a sharp Xacto knife to cut anything that was too stubborn. I spent some time doing it, but I did do 13 tires at one sitting. Also, out of the 13, only one ripped a small section of a bead. The tires are now nice & clean and ready to be mounted. They have no junk foam, left over glue and anything to keep them from making a clean, tight bead against the next rim they will be installed on. I am thinking the next rims will be bead locks though. |
