11-01-2007, 08:19 PM | #1 |
Rock Crawler Join Date: Feb 2006 Location: sunny acres
| Gaps with Kreepy inserts ?
I just got a set of Kreepy inserts ( red in front, pink in rear ) for my clod and they seem to have some significant gaps after being installed. I am using a set of Axial bead lock wheels narrowed to 2" with 40 series Moabs. I did not cut or narrow the foams because I want the sidewall to be as stiff as possible. I was previously using Airsoft bbs which provided awesome traction but almost zero sidewall support. When I installed them I double checked to make sure I was not inadvertently creating a gap and drilled a 1/8" breather hole in each wheel. With them installed I can definitely feel where the seam is in the foam and when I squeeze them the tire indents with the suction at the seam. It's basically creating a flat spot in the tires. At first I thought maybe I bought the wrong size foams and they were just too short but as far as I can tell they are the right ones. This is the size I ordered. http://tcscrawlers.com/product.php?p...cat=270&page=1 I'm wondering if not narrowing them is causing them to bunch up too much so the gap is not closing or they are in fact too short? I haven't run them on the rocks yet because I'm waiting on some thermal paste for my replacement 5995. Has anyone else run into this? Thanks. |
11-01-2007, 10:19 PM | #2 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
Never had any issues with Aces! |
11-01-2007, 10:33 PM | #3 |
Glue the foam halfs together?
11-03-2007, 12:07 PM | #4 |
| Yeah I almost bought them instead mainly because I was worried about gaps. I may try that later but I think I'll run them first before I tear all those little screws out again. They seem to be somewhat better now that they sat overnight. |
11-03-2007, 12:24 PM | #5 |
Rock Stacker Join Date: May 2007 Location: I don't even know how I got here.
I believe he told me on a small batch of the very first run the cutter cut them a little short. It could be remedied by gluing the ends with some spray adhesive or the like.
11-03-2007, 01:03 PM | #6 |
That may be the case as it seems to be the reds giving me more of a problem.
