05-05-2005, 08:30 PM | #1 |
Quarry Creeper Join Date: May 2004 Location: Hartford, Connecticut
| Pics of narrowed beadlocks
Grab a backside of the beadlocks and cut it where the screwholes end: Using a spare set of faceplates, remove just the "face" portion: With 8 M3x40 screws, put the modified pieces together. You'll want to drill the holes to 3MM or 1/8, whichever you have handy: Slide all the pieces together to ensure that your cuts are clean and line up well: Another view, from the rear which shows the hollowed-out faceplate: You'll need to narrow the bead rings by the same amount that you removed from what is now the center of the wheel (formerly the backside). You'll need to remove material from both sides: Be sure to keep all of your cuts clean and even. I did all of mine with a dremel cut-off wheel chucked into my drill press. Use the adjustable table to set the hieght and do all of your cuts in groups for repeatability and matching wheels. Last edited by fullmodtxt; 05-06-2005 at 08:52 AM. |
05-07-2005, 03:02 PM | #2 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
how bout some pics with tires mounted on them?
05-08-2005, 08:08 AM | #3 |
Click below the "my stuff" sig at the bottom of the post, there is a webshots album there with pics of LSTs mounted on the narrowed wheeels.
05-12-2005, 10:55 PM | #4 |
Quarry Creeper Join Date: Mar 2004 Location: VA
Great job Fullmod ! That method looks alot easier and with a better end result than what I did.
05-13-2005, 06:46 AM | #5 |
4X, thanx! This way is a lot of cutting, but it works great! The wheels are super strong because the bolts go entirely thru all parts of the wheels. Best part is you can tune the width. If you screw them together with no middle at all, the beads of the tires will probably touch eachother! Don't know if that would work well or not, but it's nice to know you can try it! How did you do yours? I'd like to see.
05-13-2005, 07:03 AM | #6 |
Rock Crawler Join Date: Jul 2004 Location: Salt Lake
Those look great! By the way, you got a lot of Floppy disks in that first pic.
05-13-2005, 10:34 AM | #7 |
Here is a linkto how I did mine. Narrowed Maxximizers : Update |
