05-06-2005, 03:29 AM | #1 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
| Started siping my Moabs
Broke out the Dremel and started siping tires with a cutoff wheel, but I wanted bigger voids then the cutoff wheel was giving me. So I grabbed one of the grinding stones out of Dremel kit and noticed it fit into existing voids perfectly!! I'll get some better pics up, but here's how they look so far. Last edited by BENDER; 05-06-2005 at 08:57 PM. |
05-06-2005, 10:13 AM | #2 |
Rock Crawler Join Date: Nov 2004 Location: Thats a Good question
looks good,
05-06-2005, 10:31 AM | #3 | |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
You could also stack the wheels in a mandrel. | |
05-06-2005, 11:35 AM | #4 |
Here's a couple more pics, you can see it a little better.
05-06-2005, 11:52 AM | #5 | |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
Starting to look kinda like a swamper. Should work well. Keep us posted on performance. | |
05-07-2005, 08:55 PM | #6 |
| So far so good....
I had a chance to try the tires out today briefly, so far it's working good. The tires really wrap around rocks now and definitely have more bite. I still may cut a little more off them then I need to cut the rears to match. A couple pics.... |
05-07-2005, 10:10 PM | #7 |
Rock Crawler Join Date: Jan 2005 Location: and OR. if . . . . Gone Fishin :p :b :p
Nice! They look good! What you are doing for foams in those bad boys?
05-07-2005, 11:23 PM | #8 | |
I'm running heavily cut Dirt Hawg foams. They are softer and smaller in diameter then the Moab foams. I narrowed the foam first by about an inch, then cut big notches out of the inner and outer edges. | |
05-08-2005, 01:23 AM | #9 |
Pebble Pounder Join Date: Jan 2005 Location: denver
they look great!!!!!!!!!!! so when you do get to test them all out..........tell me if they work any diff............
05-13-2005, 05:01 PM | #10 |
I finished siping the rear tires. They're definitely wrapping around the rocks better, I'm not sure how it would work on Moabs without foams. I'm going to cut the fronts a little more then the rears to try and get more grip in the front then back.
05-13-2005, 05:43 PM | #11 |
Pebble Pounder Join Date: Dec 2004 Location: Delaware A Place With No Rocks!
they look good
05-15-2005, 11:33 PM | #12 |
I got a chance to do quite a bit of testing with them this weekend. They are working awesome!! Even wet, I was able to climb some big steep rock faces. I'm still going to do a little more trimming this week.
05-15-2005, 11:47 PM | #13 |
dont get to dremel crazy i think i will do it to mine to can you show your cut paters? |
05-16-2005, 10:29 AM | #14 |
Rock Crawler Join Date: Feb 2004 Location: The Gay NorthWest
i siped mine just like that bender and i siped the long knobs on the side i siped a trench all the way threw them.... ill get pics when i get home ryan |
