05-08-2005, 06:25 PM | #1 |
Rock Stacker Join Date: May 2005 Location: La Grange
| stampede tirezs
anybody know how to mount stampede rims and tires on a maxx????
05-13-2005, 09:43 PM | #2 |
Rock Stacker Join Date: Jan 2005 Location: Sutton Motorsports Headquarters
I don't have a maxx to check, but will the stock stampede hex fit on the maxx axle stub?
05-13-2005, 10:11 PM | #3 |
bendforthebone Join Date: Feb 2004 Location: Jamul
no no
05-13-2005, 10:54 PM | #4 |
Pebble Pounder Join Date: Jan 2005 Location: denver
u could une a maxx to clod adapter and they will fit righy on...........hope this helps
05-14-2005, 04:00 PM | #5 |
RCC Addict Join Date: Jun 2004 Location: ORegon
there is a couple options i can think of. use maxx to clod adapter like he said or use a 6mm drill to bore out a 12mm hex. This would weaken it so if you can use an aluminum one. Or try to find a car with a 12mm hex with a 6mm bore. Or if you have a lathe you can shave 1mm off the maxx axles to make them 5mm.
05-16-2005, 07:15 PM | #6 |
where can i get those maxx to clod adapters? tower is soled out! and will those make it so the maxx axel carrier will fit in the stampede rims?
05-17-2005, 06:20 PM | #7 |
Pebble Pounder Join Date: Aug 2004 Location: orange county n.y. , building the hydro crawler
check to make shure the pillow block/ spindle thing will hace enough clearance in the rim, or if you use widening adapters if it will bring it out past the inside of the rim.
