| | #1 |
| Pebble Pounder Join Date: May 2004
| I got a set of Kongs. Tried them once and decided I needed to narrow them. I read DD's article. I have two questions. After I cut the tire in half, I noticed a seem on each half. Is that what you used to make your measurment from? Did you measure 1/4" from that seem toward the center of the tire to come up with a total of a 3" overall tire width? |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Feb 2004 Location: Michigan
| That's what I did and it worked great, 1/4 inch from the seam. I also used a marine rubberized adhesive (home depot) that has held up great and it flexes perfect. I put the 2 halfs on maxx rims and flipped the tire bead out so I could get my hand in the tire better to apply the glue. align the tire tread and applied and layer of glue between the 2 seams. also applied a second coat about as high as the seams too. |
| | #3 |
| Sounds good. I'll start the project this week. |
| | #4 |
| I wanna be Dave Join Date: Jan 2004
| Good luck and have fun with it! |
| | #5 |
| thanks to Dirk for telling us about this AWSOME tip. Now that I added side lugs it bites alot better |
| Thread Tools | |
| Display Modes | |
