05-13-2005, 12:35 PM | #1 |
Newbie Join Date: Sep 2004 Location: denville , new jersey
| lst tires
i just got some lst's for my txt and they are unbelievable but i was wondering is anyone using the foams in them or any other modifyed setup . also do these do better with narrowed rims also, i have them on maximizers with the foams in them right now. thanks
05-13-2005, 12:43 PM | #2 |
Quarry Creeper Join Date: May 2004 Location: Hartford, Connecticut
I ran mine on Maximizers with the foams that come with the tires for a short period of time. I did not like them. The carcass of the tire is too gooshy for my taste, but the tread blocks are great. I run the tires on narrowed beadlocks now, airtight (@atmospheric pressure) with no foams. They work very well for me now.
05-13-2005, 01:48 PM | #3 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
Use the search button and you'll find numerous topics on this.... Most of us do not run any foam and run them on narrowed wheels.
05-13-2005, 09:41 PM | #4 |
Rock Stacker Join Date: Jan 2005 Location: Sutton Motorsports Headquarters
I run mine with the foams narrowed and triangles cut out on the imex pluto 1/8 scale buggy wheels. I like them better with the foams.
05-14-2005, 08:12 AM | #5 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
i run mine on narrowed rims that are about 1.5" wide. i cut probably about 1/2"-3/4" off the foams ( width wise) and run them. i run foams because the tire is so soft. it works good for me. its just all trial and error and see what works best for ya
05-14-2005, 12:18 PM | #6 |
I run mine without foams, and a big hole drilled in the RPM StableMaxx wheels. And I still don't think they're pliable enough for the lightweight truck I have. However, on the TXT I use, with air-tight Maximizer wheels, no foams, they work well. |
05-14-2005, 01:25 PM | #7 |
RCC Addict Join Date: Jun 2004 Location: ORegon
I havn't run mine yet. But mine have air valves in them so that i can use air to hold them. It is great cause i can let the pressure out to be the equivalent of no foams or i can give them a few pumps to be a little more firm or i can pump them up real good and then they grow an inch. It is pretty cool. Just about to make a thread on this.
