Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: need some help with brazing
Old 02-02-2008, 09:59 PM   #1
Default need some help with brazing
I noticed that you guys braze your tube chassis together. but the question that I have is how hot do you have to get the the tube and brazing rod for it to braze properly? thanks.
iceman320 is offline   Reply With Quote
Old 02-02-2008, 11:09 PM   #2
I'm a stupid C U N T!
glowing, the only way to know for sure is to heat it up and touch it with brazing rod if it melts you're good
slobin3d is offline   Reply With Quote
Old 02-03-2008, 10:53 AM   #3
would 2500 degrees do the trick?
Old 02-03-2008, 12:00 PM   #4
Mapp gas gets to 2509 I think it was and it is what most people use, so yeah.
CrawlinClodKiller is offline   Reply With Quote
Old 02-03-2008, 12:09 PM   #5
cool I might order a torch for tower then thanks.
Old 02-03-2008, 12:16 PM   #6
IMO, don't bother with one of those micro torches from tower. A simple bottle of MAPP run with a MAPP/PROPANE (plumbing) torch just works so much better.
Robb is offline   Reply With Quote
Old 02-03-2008, 01:48 PM   #7
and try not to over heat the tube it will turn the joints black i get the tube red hot and when the braze starts to melt o move the torch away abit to keep it from over heating have fun its not as hard as it looks
frsttimer is offline   Reply With Quote
Old 02-03-2008, 05:20 PM   #8
I found that getting the tubing med. hot then melting a little solder onto the joint then heat until that solder BB loses its surface tension and fills the joint. I hope that makes sense.
Greg337 is offline   Reply With Quote
Old 02-03-2008, 05:50 PM   #9
ok thanks for the help guys I think that my dad has a propane torch somewhere I will have to go over and see if I can find it. thanks again.
