06-28-2014, 01:50 PM | #1 |
| Mini sandblaster
I dont have room for sandblasting cabinet. I have small compressor. So my 2 questions... 1. Im looking at getting a badger mini sandblaster.Any better options. I dont really want to have to find a shop to have this done everytime. http://www.amazon.com/gp/aw/d/B001MA...&robot_redir=1 2. I would using it to clean up tube work of old paint and light surface rust. What media would be best to use. Last edited by eric113; 06-28-2014 at 01:53 PM. |
06-29-2014, 10:06 AM | #2 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: Mini sandblaster
My guess is that is not going to accomplish what you want. It is designed for mirror etching, the media they recommend is going to be very fine. I doubt you can really deviate much from that due to the design and small size of the unit head. Just observations, not first hand experience with that product. I have used many blast cabinets in the past, I would go down that road instead. You can build a small cabinet out of a plastic bin and some rubber gloves with a clear plastic/visqueen top and some duct tape that will store nicely. The blast gun is readily avalable at places like grainer or harbor frieght. Here is a dyi one of our local guys came up with. Hard Body Media Blasting - WARCRC |
07-01-2014, 09:25 AM | #3 |
Thanks D. Your probably right about the nozzel size. I have looked at picking up a habor frieght gun. I seen few of the diy storage container sandblasters.
07-01-2014, 10:31 AM | #4 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Air Erasers (Mini Sandblasters) are actually pretty capable units. Search youtube and you will see they can take off a lot of stuff. Many people using baking soda as a medium. The big issue with them is not their ability to take off stuff, just the time it takes to cover area because of their size. Later EddieO |
07-01-2014, 11:16 AM | #5 |
I have been searching all over web and you tube for mini sandblaster (air erasers) and havent found much, mostly homejobby ones. I dont think baking soda is going be aggressive enough for paint, prime, light surface rust. I read baking soda is more a polish or clean up grimey parts.
07-01-2014, 12:36 PM | #6 | |
| Re: Mini sandblaster Quote:
07-03-2014, 01:55 AM | #7 |
| Re: Mini sandblaster https://m.youtube.com/watch?v=yeUMMRRGYbU This guy is using it to strip hot wheels... Which is a very tough paint. I used them as a kid to strip down all kinds of stuff... We used baking soda then as well. While sometimes the coarser stuff is needed, the baking soda worked on most stuff.... Cheap too Later EddieO |
07-03-2014, 09:20 AM | #8 |
I ordered a badger kit to try out. I give the baking soda a try.
07-04-2014, 11:45 PM | #9 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
That's nice, it would defiantly come in handy with what I do like stripping old pair off of beadlocks and stuff. I might just get the first one you said eric113.
11-22-2014, 04:05 PM | #10 |
I finally got one after having to cancel my order from one place and order from another. I haven't had a chance to try it out. I'm going to try the baking soda first. I will post up when I start using it.
11-25-2014, 01:12 PM | #11 |
eric113, Please post your results. I am now in the market and would be curious how it works. Thanks Mike |
11-27-2014, 07:35 AM | #12 |
I finally got a chance to use it. Pretty easy to use.If you going to use your air compressor all you need is a 1/4'' male air quick connecter. I turn up the compressor to 80 p.s.i. I didn't use the meda that came with the kit. I used baking soda per EddieO. It work ok, I think something more course will work faster. I had new bright JK body that was given to me and has 4-5 coats of paint. You can see the layers. It also work on tube work paint. For me and what I'm using it for I think it will work good. I'm going to be trying out other media. WORD OF CAUTION... be very careful where you sit the baster!!!! I ended breaking the glass jar. So I need to order a new one. |
11-27-2014, 02:36 PM | #13 |
nice! the baking soda is nice for not destroying all the body details
11-27-2014, 03:52 PM | #14 |
I use a speed blaster. http://www.amazon.com/Unitec-UNI007B...=speed+blaster It only gets used for metal, so regular old play sand does the job. |
12-12-2014, 02:34 PM | #15 | |
I also been thinking about trying black beauty media. I heard it suppose to be good. http://www.amazon.com/gp/aw/d/B0053G..._SS115&simLd=1 | |
12-12-2014, 04:15 PM | #16 | ||
12-13-2014, 12:08 AM | #17 |
I have used HF air eraser on some corroded nitro blocks and the elbow that gets the caked on black crap all over it as well as some 1:1 rotors with minor surface rust. Didn't use media that came with it but some regular baking soda and it did very well. Have to refill often and shake sometimes though. Think it only holds an ounce or two
12-13-2014, 07:57 AM | #18 |
| Re: Mini sandblaster It works well enough. It strips paint/primer/rust/whatever and doesn't leave the cage too rough. Some areas can be hard to reach, but not impossible. Media flow is adjustable.
12-13-2014, 09:33 AM | #19 | |
12-18-2014, 09:06 AM | #20 |
So I tried play sand and no dice. I dont know if black beauty would be too course. I think im going have to pick up a harbor frieght gun. 1 Liter Abrasive Blast Gun |
Mini sandblaster - Similar Threads | ||||
Anyone have a sandblaster? | scale4x4 | Florida | 0 | 01-16-2014 08:30 AM |
Losi Mini LST2, Traxxas Mini Slash, or Mini revo. | CrawlinMike | Non Crawler RC's | 10 | 07-14-2009 06:53 PM |
Sandblaster | 666 | Colorado | 7 | 06-06-2008 09:08 AM |
I Need a Sandblaster and Powder Coater in CO... | TwistedXT | Colorado | 4 | 02-03-2008 08:01 PM |
