Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: will this cut
Old 06-25-2005, 11:39 AM   #1
Default will this cut
i have some alum sheet its .064 in thickness, i want to make sumthin with it but i have nuthing to cut it. and i went to my garage to look for sumthin and found a skillsaw variable speed jigsaw, its 3.0 amp motor 1/3 hp. 0-3200 s.p.m. so will this work to cut it?
AQTHF BIATCH is offline   Reply With Quote
Old 06-25-2005, 03:18 PM   #2
It should, just get some fine toothed blades designed to cut metal. Go slow, and use some cutting oil or if you don't have any, motor oil will suffice.
AdamF is offline   Reply With Quote
