04-02-2008, 07:14 PM | #1 |
Rock Stacker Join Date: Oct 2007 Location: Bundaberg, QLD, Australia
| Brazing with Butane Soldering Iron with Flame Tip?
I already have a Butane Soldering Iron and it has a flame Tip... I have this http://www.butanetools.com/Pro70K.htm Can i use this and just get some of the silver brazing "solder" and flux? or do i need to go get a proper map torch? |
04-02-2008, 07:37 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
Butane dosn't get hot enough for brazing, get mapps.
04-02-2008, 07:46 PM | #3 |
Generally it will come in a container like this : |
04-02-2008, 09:04 PM | #4 |
04-02-2008, 09:11 PM | #5 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Which brazing threads did you search through to discover that a butane soldering iron would be an appropriate tool?
04-02-2008, 11:09 PM | #6 |
Rock Crawler Join Date: Nov 2004 Location: Roseville
04-03-2008, 07:24 AM | #7 |
04-12-2008, 06:42 PM | #8 |
Rock Crawler Join Date: Mar 2008 Location: hillbilly illinois
Thats funny. He said get mapps and jrh posted that lol
04-16-2008, 03:46 AM | #9 |
Quarry Creeper Join Date: Sep 2007 Location: Middle of the USA
Butane cannot get to the melting point of soldier and hold a steady temp. You need mapp gas or mapp?O2 to fill your needs! |
04-19-2008, 12:45 PM | #10 |
Pebble Pounder Join Date: Jan 2008 Location: Woodinville, Washington
I tried to use mine just to tack some brake line together then go back over with a mapp and braze, yea didnt work at all... cant get the brake line hot enough to get the solder to stick just formed a little puddle that i could flick off when it was cool.
04-29-2008, 03:57 PM | #11 |
RCC Addict Join Date: Feb 2007 Location: sweden
I actually use a butane torch to braze, only thing i noticed is that brazing steel rod is way easyer then copper brakeline tube thats what i noticed, when i tryed to braze brakeline i had to use 2 butane torches but now when i did my roolcage in steel it worked out great, but im sure a mapp torch is better, i use some silver and flux from my local hardware store.
