04-12-2008, 09:26 PM | #1 |
Rock Stacker Join Date: Dec 2006 Location: in the workshop
| Dimple Die's?
Does anyone use, know how to get, or have the ability to make small dimple dies? , I'm considering using some for a scale type build for strenght and also just for the "cool" factor.
04-12-2008, 11:18 PM | #2 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
Buy a machine bolt and nut, what ever size you want the hole to be, this one is a 1/4". Drill out the top of the nut so it is tapered, then drill a hole and bolt the nut on really hard and you've got a dimple died hole. Super cheap too. Here's an example of some I did on a tuber I built. Spyder Customs Bruiser Tuber |
04-13-2008, 01:11 AM | #3 |
Quarry Creeper Join Date: Nov 2007 Location: Alberta canada
Someone explain to me what this is for?
04-13-2008, 06:37 AM | #4 | |
Thanks, wrecker, I was trying to think along these lines but the ideas I had in my head were alot more complicated | |
04-13-2008, 06:40 AM | #5 |
| slowkrawl: it takes a piece of flat sheetmetal and by "dimpling" it it gives it some rigidity so that it doesent flex, they use it on real 1:1's, and race cars and you even see it on some street cars usually on the rear axle of a small front wheel drive car
04-13-2008, 11:58 AM | #6 | |
04-14-2008, 06:56 AM | #7 |
Quarry Creeper Join Date: Jan 2008 Location: marysville
Good thinkin Wrecker. |
04-14-2008, 08:44 AM | #8 |
04-15-2008, 12:36 PM | #9 |
Quarry Creeper Join Date: Nov 2005 Location: Danville
Damn thats a really cool idea! Dimple Die holes always look so bad ass on 1:1 rigs, this is a great easy way to add them to rc. |
04-18-2008, 02:17 AM | #10 |
Rock Stacker Join Date: Jan 2006 Location: Pee Gee
yardstore.com is an aircraft building supply place and they sell little tiny dimple dies. They are about $15 for one, so the countersunk bolt trick is cheaper, but these would be the most repeatable results. Plus, you can get them for many different hole sizes. Here is a link to the 3/16 size: http://www.yardstore.com/browse.cfm/4,3710.html |
04-18-2008, 07:14 AM | #11 |
Pebble Pounder Join Date: Apr 2007 Location: Deer Park
yea but the ones posted at yardstore require a specialized tool to put them in with
04-18-2008, 08:07 AM | #12 | |
rok dok these should work in a small arbor press (little modification mabey) and harbour freight often has a small arbor press on sale cheap and I could think of so many other things I could do with it, or you could justt drill some holes in a block of wood or metal for the posts that come out the back of these and use them in a vice | |
04-19-2008, 01:04 AM | #13 |
Quarry Creeper Join Date: Aug 2006 Location: NORTH TEXAS
I have used these before. http://www.harborfreightusa.com/usa/...emnumber=93539 |
11-06-2008, 09:40 AM | #14 |
Newbie Join Date: Nov 2008 Location: va
| Pop Rivet Dimple Dies
I didnt see anyone else mention it so i thought i would. http://www.averytools.com/p-857-pop-rivet-dimplers.aspx Dimple dies in a variety of teeny sizes that use your pop rivet gun as the press. Last edited by kawgomoo; 11-06-2008 at 02:50 PM. |
11-06-2008, 02:29 PM | #15 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
I've been considering making one, but haven't yet & for $15 that's likely not to happen
