06-19-2008, 10:25 AM | #1 |
Quarry Creeper Join Date: Aug 2006 Location: Baumholder
| delrin rod
does anybody know where i can get some delrin rod so i can build some links, also what size should i get?
06-19-2008, 10:29 AM | #2 |
Pebble Pounder Join Date: Jun 2008 Location: Central Florida
06-19-2008, 10:38 AM | #3 |
Thanks man
06-19-2008, 10:42 AM | #4 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
| ..................bob .... |
07-08-2008, 02:03 PM | #5 |
Rock Stacker Join Date: Mar 2007 Location: WV
What Diameter?
07-08-2008, 04:11 PM | #6 | |
Pebble Pounder Join Date: Dec 2005 Location: Metro NYC
| Quote: | |
07-08-2008, 06:18 PM | #7 |
| Yes indeed!! MSC is another good source for materials, tooling, etc. http://www1.mscdirect.com/cgi/nnsrhm |
07-08-2008, 06:28 PM | #8 |
Rock Crawler Join Date: Feb 2007 Location: In A Nut Shell
dont forget Mcmastercarr!
07-09-2008, 08:27 PM | #9 |
what diameter, please
07-09-2008, 09:57 PM | #10 |
Quarry Creeper Join Date: Jan 2007 Location: Kansas City
I usually use 5/16" with 8/32 all thread and jato rod ends. Works out great for me and others I also have 1/4" rod I use for other stuff like chassis braces and steering linkage.
07-12-2008, 06:27 AM | #11 |
Thanks for the help
07-12-2008, 06:36 AM | #12 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
I get mine from www.usplastic.com |
07-12-2008, 04:41 PM | #13 |
Thanks for all the help, I finally found the right size but I have one more question if I needed to make bent links out of delrin how would I do that? I was thinking of heating them up but then they would be fragile, I also thought of makeing a mold, any help would be great. Thanks in advance.
07-12-2008, 07:26 PM | #14 |
Newbie Join Date: May 2007 Location: Oahu, Hawaii
use-enco.com is the cheapest
07-12-2008, 08:30 PM | #15 | |
Just let it cool slowly (dont quench it in cold water) | |
07-13-2008, 12:06 AM | #16 |
thanks for the help
07-13-2008, 08:34 AM | #17 |
You also have to heat it carefully. If you heat it to fast or to long it'll deform when you bend it. Then it'll be weaker. Heat it slow and even.
07-14-2008, 10:34 AM | #18 |
Rock Crawler Join Date: May 2007 Location: Glendora
8/32 all thread???? Are those just long set screws? Where can I get some?
07-14-2008, 10:44 AM | #19 |
all thread is a long stock of threaded rod you can pick it up at any local hardware store. |
07-14-2008, 10:01 PM | #20 |
