06-23-2008, 04:16 AM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: Italy
| Movement of the axle: can autocad help ?
I'm wondering if autocad can help in simulating the movement of tha axle relative to the chassis. I'm a newbe so I would start from a 2D model with a side view of the crawler. I would like to simulate how the axle moves changing link lenghts and positions (in 2D a 4 link suspensions become a 2 link and I'm not interested in axle twist at this time). I don't have any idea on how to start. I need to tell autocad that links can rotate at the center of their extremity, cannot do any other movements and that the points of the objects connected to the links must mantain the same distance. Any suggestions will be very appreciated. Nobody with an example ? Thanks Filippo |
06-24-2008, 10:14 PM | #2 |
I joined the Band! Join Date: Mar 2006 Location: Gardena,Ca.
you would need solid works for that
06-25-2008, 03:52 AM | #3 |
Rock Stacker Join Date: Jan 2008 Location: Edmonton
It's doable in AutoCAD using LISP. Alternatively, you could use 3D Studio Max or Blender to "animate" your drawings from AutoCAD, or even draw them in the programs themselves. SolidWorks is a much better option, the rest are kind of hack jobs. I'm not sure on this, but you may be able to use Sketchup as well. It's a whole lot cheaper than the pro tools and emulates a lot of the features. Good luck! |
06-25-2008, 04:45 PM | #4 |
Rock Crawler Join Date: Feb 2007 Location: In A Nut Shell
Solidworks all the way is uber easy to do what you want. i have auto cad and only use it for architectural design. |
06-29-2008, 05:33 PM | #5 |
Newbie Join Date: Jul 2007 Location: westampton new
I use Prodesktop 8.0
06-30-2008, 11:18 AM | #6 |
06-30-2008, 07:26 PM | #7 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Swingy swingy......... |
06-30-2008, 07:58 PM | #8 |
06-30-2008, 08:02 PM | #9 |
06-30-2008, 08:09 PM | #10 |
