09-03-2008, 04:25 PM | #1 |
RCC Addict Join Date: Jun 2008 Location: Fresno
| non-scratch pliers?
can somone recommend a good set of non scratch pliers? an lhs by my place sells the tamiya ones for like $30, and honestly i think thats pretty over priced ive seen the duratraxx and hobbico ones online going for like 8 dollars anyone have any experience w/ them? |
09-03-2008, 04:39 PM | #2 |
Unfortunaty there all pretty pricey. RCP has some for shock shafts that look really nice their about $30 to.
09-04-2008, 05:07 PM | #3 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
basic flat duckbill pliers work perfect with 2 or 3 layers of painter's masking tape on the jaws. Been using these forever with the aircraft. Get a dent, change the tape. 1 roll of tape will last approximately 57.4 years.
09-04-2008, 05:15 PM | #4 |
support@rc4wd.com Join Date: Nov 2007 Location: Lancaster, Ohio
09-04-2008, 06:10 PM | #5 |
Pebble Pounder Join Date: Apr 2008 Location: greenville
look around in sears they selll rubber covers that fit almost any pliers youd need and they werent more then a few bucks a pair
09-04-2008, 08:44 PM | #6 |
Quarry Creeper Join Date: Apr 2007 Location: St. Louis
There is a product available, it's name escapes me, where you can re-do the plastic ends on your pliers. Plasti-Dip maybe? Who says you have to use it on the handles. I found it in my local hardware store.
09-04-2008, 09:18 PM | #7 |
A bit different method that I use..... What ever thread in on the shock shaft,example,if it's 3mm....I'll either run a 3mm bolt or a 3mm tap inside the rod end. This forms/cuts the threads needed and you can then hold the shaft with your fingers while threading the rod end on. Works great for me. |
09-05-2008, 08:37 AM | #8 | |
i cant believe i didnt think of that i have some plasti dip hanging around in my tool box. i mainly use it for covering the blades on my balisongs for practice | |
09-05-2008, 10:09 AM | #9 |
Quarry Creeper Join Date: Dec 2006 Location: Western Mass
I've been using the Craftman Robogrip pliers (they come with hard rubber covers) and can really hold. Not to mention, good for other stuff too.
09-07-2008, 10:07 AM | #10 |
Rock Stacker Join Date: Sep 2007 Location: east mich
| coat them i plastic dip
09-07-2008, 12:48 PM | #11 |
I can't see plasti-dip holding up the cheap duratrax sounds like a better option.
09-09-2008, 09:39 PM | #12 |
Newbie Join Date: Jul 2008 Location: South Decatur
i wad my shirt around whatever i'm pinching with the pliers then clamp down it works like a charm. I've used it on shocks, links, everything
09-11-2008, 12:30 AM | #13 |
09-11-2008, 12:41 AM | #14 |
RCC Addict Join Date: Nov 2007 Location: BV
I got this one from jgoodall. Go buy the cheapest wire cutters you can find (I mean really shitty, like the cheapest ones at harbor freight) then try to cut a nail with them. If they're terrible enough, they'll dent into the perfect shape to hold a shock shaft |
09-11-2008, 12:37 PM | #15 | |
09-11-2008, 01:45 PM | #16 | |
09-11-2008, 07:04 PM | #17 |
09-11-2008, 09:44 PM | #18 |
Rock Stacker Join Date: Jul 2008 Location: the zone
09-16-2008, 11:49 AM | #19 |
Rock Crawler Join Date: Apr 2008 Location: Lexington
Look on McMaster for part #'s: 53085A61 & 53058A62. Never used those, but I think it's what you're looking for. $7.43 and $8.27 respectively.
09-21-2008, 08:49 PM | #20 |
Newbie Join Date: Sep 2008 Location: Orlando
I don't know if this would work but for tweezers (i have 12 inch long ones ) i need something that won't damage/scratch, i take a piece of air tubing and slip it over the end. It won't scratch and it gives pretty good grip too. |
