| | #1 |
| Pebble Pounder Join Date: Apr 2005 Location: i'm not sure
| Ok i'm looking into buying a band saw but i'm not sure witch one to get. I was looking at the hf one but I heard that there tools are very cheap. So are there any other one that would work for rc stuff? |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Jul 2007 Location: Planet Earth
| Craftsman 12 in. Band Saw for metal cutting?? Check here it may have the information your looking for. It also contains information on cutting techniques, recommended band saws and blades. Hope this helps. |
| | #3 |
| RCC Addict Join Date: Mar 2008 Location: lackawaxen, pike county. PA
| try these guys out.... http://www.grizzlyindustrial.com/pro...spx?q=bandsaws my friend has this saw the G0555 14" saw is a good saw, even if just for RC work....but will handle other work real good..............bob .... |
| | #4 |
| Pebble Pounder Join Date: Jun 2008 Location: Central Florida
| It really comes down to what you want to cut. A high speed, wood bandsaw will cut thinner aluminum, brass, etc.,. If you want to cut steel, titanium or thicker soft metals you need a low speed bandsaw. Dual range saws can get pretty expensive but will do everything. I've been using the 14" Wilton Tradesman saw for years and it's held up well to hard use. It has a high and low range and cuts like a SOB http://www.southern-tool.com/store/t...n_bandsaw.html Last edited by FL Knifemaker; 06-27-2008 at 02:14 PM. |
| Thread Tools | |
| Display Modes | |
