01-19-2009, 06:13 PM | #1 |
Quarry Creeper Join Date: Sep 2008 Location: Where there are no rocks.
| Lathe?
Anyone have a small lathe they can turn metal (aluminum) with? All i can find is wood ones. I used to work in a machine shop/metal shop/ welding shop when i was in the airforce. Unfortunatly that was before i started this hobby. and now i need something to widdle metal with at home. anyone? maybe i should take a huge paycut and get back in so i can make parts for my crawlers... no sure the wife would like that... |
01-19-2009, 07:04 PM | #2 | |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
01-27-2009, 08:52 AM | #3 |
Pebble Pounder Join Date: Jul 2006 Location: Out of my mind!!
Check out harbor freight, they've got several, or craigslist-where I found my Unimat, which I love-you can set it up to be a mill, also.
01-27-2009, 09:47 AM | #4 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
| Sherline Mills and Lathes
Harbor Freight will get you the least $$ new one. I have a small Sherline Vertical mill on perm-loan to me. It's a blast. The also make lathes. What's great about Sherline is that they still make the exact model and parts for the mill I got ............that is 30yrs old, but NEW in the box As long as they can make it through recessions, parts will always be avail. They are pricey at $650+ http://www.sherline.com/ |
01-27-2009, 10:21 PM | #5 |
Newbie Join Date: Jan 2009 Location: Upper Darby
i got a 7x10 (they're all made by the same co. in japan and renamed/painted) I'm a tattoo artist and tattoo machine maker and i got it for turning parts for that bus. but hell that's going to be supporting this habit. You can do a lot of stuff out of the box, but it's a whole lot of tweaking and research. Check out http://www.mini-lathe.com for some good info and http://www.littlemachineshop.com for accessories. Def. get their mini-lathe tooling package, will cut your times drastically for turning anything.
01-27-2009, 11:58 PM | #6 | |
But on another note, check out mini-lathe.com, well worth it, you may also want to join a 7x yahoo group | |
01-28-2009, 06:30 PM | #7 |
Pebble Pounder Join Date: Dec 2008 Location: Tomball, Tx
If you come across an OLD craftsman (i believe they were made by Atlas) metal cutting lathe, snap it up and don't think twice about the price. My 7x19 is older than me and better than anything you can buy new today IMO.
01-28-2009, 06:51 PM | #8 |
| Good point. Some older machines are far better than any new machine you can buy. The lathe I run at work was built in 1956. It's one of the most accurate and dependable machines we have at work. She's kinda rough looking,but she's a work horse. It'll hold +/- .001" tolerance all day long. Kinda sucks though,I can't hold on to anything small enough to make RC parts with it. Maybe a 40 series or maxx size wheel. |
01-29-2009, 05:48 AM | #9 | |
01-29-2009, 08:48 AM | #10 |
I've heard great things about the Atlas. I wouldn't mind having one.
01-29-2009, 10:11 AM | #11 |
Newbie Join Date: Nov 2008 Location: Kansas City
I was told a long time ago by a good friend that mass produces machined scale parts for scale model builders "Get the BIGGEST machine you can afford... small machines do small parts while big machines can do anything up to the size limit of the machine". I've had one of these in my garage for over 4 years now - http://www.grizzley.com/products/Combo-Lathe-Mill/G9729 not the best for mass production, but for small run parts that I have done for scale models up to making custom parts for motorcycles, it's been good. Granted it is more pricey and a LOT bigger/heavier than the small units (this one is just under 900lbs) but worth it if you have the room. Pat |
01-29-2009, 08:00 PM | #12 |
this might have some useful info. look at the videos link and the links. http://www.lautard.com/ more great info. plenty of good articles http://www.homemetalshopclub.org/index.html this one is more to the point of this thread "buying a small lathe" http://www.homemetalshopclub.org/new...98.html#Buying |
