02-02-2009, 10:47 PM | #21 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
I'm building all the front links and probably the rear upers on Ivy. Was planning on delrin with 4mm studs & Revos, but your's look like the real deal.
02-02-2009, 11:28 PM | #22 |
Pebble Pounder Join Date: Jan 2008 Location: E. Concord
Some times i will make some links out of 1/8 steel rod. cut it to length and put it in the chuck of a drill and run it into a dye. it depends on the application and location to what i make links out of. have made out of 1/4 aluminum, delrin, esc. Depends on what is avail at the time i guess
02-03-2009, 07:57 AM | #23 |
Pebble Pounder Join Date: Dec 2008 Location: MIDDLE TN.
Ya'll do some nice work JEFF |
08-06-2009, 10:43 PM | #24 |
Quarry Creeper Join Date: Aug 2009 Location: Philadelphia, PA
| Taps and Dies
A place called micro mark, they have been around for 15-20 years or more. They also have other handy small tools that we could use. www.micromark.com |
08-07-2009, 01:28 AM | #25 |
Quarry Creeper Join Date: Sep 2007 Location: Near my tools
I dont use tap though. I just cut from brakeline tubing how much length I want and braze it with screw on all ends.
08-07-2009, 08:32 AM | #26 |
| Any reason for Jato on one end and Revo on the other? I just made mine up with 8-32 all-thread, stainless 1/4" and Jato's on both ends.
08-07-2009, 09:55 AM | #27 |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
well 1/4" delrin tapped to 3mm on the mini, 5/16" delrin tapped to 3mm on the berg, and 1/2" delrin tapped to 4mm, all with solid delrin rod. I use a drill press to tap and to bevel the ends of the links a hack saw to cut the links and files to get the links smooth. I get my taps from this place (along with all my other hardware) http://www.aaametric.com/, its a local place and i can get things much cheaper there than places like hobby stores and hardware stores. |
08-07-2009, 10:48 AM | #28 |
Pebble Pounder Join Date: Jun 2009 Location: Jackson
08-07-2009, 01:34 PM | #29 |
08-07-2009, 05:04 PM | #30 |
Oh, so everything else being equal, the length from the face of the link to the centerline of the joint would be different. Could also be accomplished with spacers, I suppose. |
08-07-2009, 06:40 PM | #31 | ||
I originally built the links for a 17" wb and later decided I wanted it a bit longer. Swapping on the Jato ends was just a quicker and easier way of gaining 3/8" of wheelbase than building all new links. Spacers would use up valuable thread engagement into the rod end. To use spacers you would need to cut longer all thread. Swapping on the Jato ends didn't require building anything new, although it would be a good idea to cut new all thread to get as much thread engagement as possible. Last edited by Grizzly4x4; 08-07-2009 at 06:44 PM. | ||
08-07-2009, 10:49 PM | #32 | |
Rock Crawler Join Date: Oct 2008 Location: Florida
08-09-2009, 05:11 AM | #33 |
Quarry Creeper Join Date: Jan 2009 Location: North Wales, UK.
Tried to compile a list of Rod ends/Part Numbers but it's in metric... http://www.ukrcrc.com/forum/viewtopic.php?t=4107 |
08-09-2009, 01:09 PM | #34 |
Newbie Join Date: Apr 2007 Location: tacoma
08-18-2009, 03:09 PM | #35 |
Rock Stacker Join Date: Jul 2008 Location: Rocklin/Jackson CA
lowes sells threaded rod,then u just slip brakline over it,no tap needed |
08-18-2009, 05:51 PM | #36 |
Rock Stacker Join Date: Aug 2004 Location: Norwalk, Ca
i made mine out of all thread and tubing
11-22-2009, 01:46 AM | #37 |
Newbie Join Date: Oct 2009 Location: Calgary
I work in a Paintball Pro Shop and was looking for some Delrin stock to make some links with. You can never find anything when you are looking for it, but after it appears. I found some Macro Line used in the paintball industry to transfer air from the ASA (where the tank screws in) to the main gun. This Macro line is made of a high pressure plastic, it can take pressure to 3000 psi and is some what flexable tube. I can use a knife to cut it into any length I want and use a hair dryer to shape it straight. I happen to have Macro line with two different inside diamaters. The one size is just shy of the 3mm set screw used on the Axial links. I just thread the set screw in and it cuts it's own threads into the plastic and I then put a Axial end on. The second Macro Line tubes inside diamater is a bit bigger. Big enough to be able to put bolts threw and use it as spacers. I just cut it to any size i need. All this Macro line I use was just scraps from what is left. Below are some pictures of what I used and how it turned out. It slides real nice on rocks and stuff. I have only used it on my scale I am building, but it should slide real nice on rocks and such. Next I am going to use some of the Macro Line in a bumper build. |
11-24-2009, 08:50 PM | #38 |
Rock Stacker Join Date: Oct 2009 Location: Cranston
Those might bend pretty easily. The stainless or brakeline adds rigity to them and makes them a hell of a lot tougher. Good find though.
12-26-2010, 04:13 PM | #39 |
Newbie Join Date: Nov 2010 Location: North Shore,Hawaii Mutha Truckas!
12-05-2011, 06:13 PM | #40 |
Quarry Creeper Join Date: Sep 2011 Location: Columbus, Ohio USA
Lets bring this thread back from the dead 10/32 is some beefy all-thread I'm adding a link to this for the Wraith guys |
Tags |
link, links |
