10-09-2005, 05:42 PM | #1 |
Quarry Creeper Join Date: Jan 2004 Location: CSU, CO
| Would this work? (notching tube with a mill)
I am in the process of making my tuber. I currently need to notch the tubing so I can weld it up. I need the notches to be parallel to the bottom of the frame. Like so: I could use a circular file to do the notches, but since I recently got a mill, figured I should use it. The only way I can see this being done is with a ball ended mill. Like so: There is the vice, two 1/4" aluminum plates to spread the load, and the end mill. What are the chances of this setup working? Any other suggestions to get the notches done? |
10-09-2005, 09:35 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
That should work, 1/4" vice jaws might be a little on the thin side. Maybe try to find some 1/2" thick material for the vice jaws. I'd cut as much excess tubing off as possible with a saw before milling it, the endmill will be less likely to grab the tubing.
10-09-2005, 10:54 PM | #3 |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
It'll work, just gotta clamp the tube close to the edge so it doesn't jump around. I found it more trouble so I do it with hand files or an abrasive cutoff wheel and cleaned with a file. Jay |
10-09-2005, 11:01 PM | #4 | |
I have a drill press vice and not a proper mill vice. | |
10-10-2005, 08:04 AM | #5 |
I'm talking about the custom vice jaws that are holding the tubing in the 2nd pic. It might be thick enough, I'm just used to set-ups being overkill as far as rigidity goes.
10-10-2005, 02:11 PM | #6 | |
Pebble Pounder Join Date: Oct 2004 Location: Colorado
Most portable Commercial Pipe Notching units, http://www.off-road.com/chevy/jointjigger/notcher.html use a “Hole Saw”. For large DOM tubing for roll bars and such, an annular cutter mounted in a large Bridgeport size Mill works better than an end mill. http://www.thefabricator.com/TubePip...le.cfm?ID=1151 Specilized lathes using end mills like this do exist though. http://www.bii1.com/notcher_tubeandpipe.htm For brake tubing, I use a round file used to sharpen chain saw blades. Brake tubing is so soft that you waste more time trying to hold it rigidly in your fixture than you spend by just filing it by hand. Quote:
10-14-2005, 05:36 PM | #7 |
Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
Should work. The tube is probably buldged down at the two bends. So, the 1/4" vice plates will only really grab the tube down there. The ends of the tubes where your cutting will bounce around and chatter. Could try gripping just up by the tube end, seperately for each cut. Or maybe adding some cardboard to the vice "jaws" to add compliance, or ??? |
10-23-2005, 04:00 PM | #8 | |
10-23-2005, 06:02 PM | #9 |
it took a long time for me to set up and mill each individual tube on my mill. I ended up using a file as well, it was faster.
