10-14-2005, 08:41 PM | #1 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
| Brazing Material Compatability
For my Winter project, I am planning a tube chassis. I want to mount my shocks and links to brackets brazed to the frame that have multiple holes so I can vary the setup, instead of making hoops out of tubing with only one mounting option. What material should I use? I know you can braze dissimilar metals, but then you have issues with the different materials expanding and contracting at different rates. So where can I find appropriate sheet metal similar to the steel used for brakeline? Also, will brazing these flat mounting brackets onto the tubing be strong enough?
10-14-2005, 08:44 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Moved to Tools and Procedures, it'll get more views here. |
10-20-2005, 02:32 PM | #3 |
Rock Stacker Join Date: Oct 2005 Location: Puget Sound
I am not sure that you have too much to worry about here, since most environmental temp changes will not pose a real threat to your project.. Even if it did pose a threat, most sheetmetal is made from a similar material as brakeline anyway. Your only real issue, should you decide to braze dissimilar materials, is that of finding brazing rods/materials that work for both materials (i.e. AL and Steel), but that may just be for true welding...
10-20-2005, 05:34 PM | #4 |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Just go to any steel or scrap place and buy some plain old 16 gauge (1/16") steel sheet which will work fine with the brakeline. Jay |
10-23-2005, 09:34 PM | #5 |
Dreadshawn - The issue with different expansion rates of different metals after construction isn't what I was concerned about. It is during the process that I was referring to. If you braze dissimilar metals together, as they cool, one will shrink more/faster than the other, thus posing a risk of cracking the newly formed connection as it cools. Looks like I'll be picking up some good ol' steel plate. Thanks Roktoy. Also, I have seen hex nuts attached to frames for side-plate mounting. But, I am not sure if these have been welded or brazed on. Would I be able to braze on some hex nuts to bolt side plates to? |
11-01-2005, 06:55 AM | #6 | |
Jay | |
