10-28-2005, 07:31 PM | #1 |
Pebble Pounder Join Date: Oct 2004 Location: san francisco
| black and decker dremel
how long do you guys use it till it gets really hot? like 150+º F cause i just got one and it gets hot pretty quick
10-28-2005, 09:57 PM | #2 |
Newbie Join Date: Oct 2005 Location: Burbs of chicago
I have one by black and decker and ive used it intensivly for like 40 mins and it wasnt realy to hot...
10-29-2005, 12:44 AM | #3 |
Quarry Creeper Join Date: Apr 2005 Location: Malaysia
It can get hot pretty quick depending on what you're doing with it. If you are cutting aluminium with a cutting disk, it gets quite hot. I usually let it take breaks to cool down if I am cutting a lot of aluminium in one go.
10-29-2005, 10:40 AM | #4 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
if a tool gets hot fast, its usually because there is too much load on the motor. So try not to push to hard. or use the right bit.
10-29-2005, 10:43 PM | #5 |
RCC Addict Join Date: Feb 2005 Location: Guam
my black and decker stays pretty cool. it hasn't gotten really hot.
10-29-2005, 11:37 PM | #6 |
oh ok thanks
11-01-2005, 07:27 AM | #7 |
Rock Stacker Join Date: Mar 2005 Location: natick mass
i was using mine for about 2 hours strait with a flex shaft on it and it got to about 200 degrees but i kept using it and seemed fine i have done that for a long time and it still works fine is built to do that
11-26-2005, 09:13 PM | #8 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
If it's getting hot use a higher speed (if you have a variable speed model, I don't know what B&D offers). I had that problem with my Craftsman (just a black, rebadged dremel) cutting, I was using too low a speed, cranked it up and it cut cleaner, faster and cooler.
11-27-2005, 10:48 AM | #9 |
Quarry Creeper Join Date: Jan 2005 Location: Westchester
I'm from the micro scene, so I should mention to be careful to use too high of a speed. If you're cutting plastic or something that will melt easily, then be careful to not use too high of a speed or it will ruin your bit, probably hurt you a little( three cheers for molten plastic), and will not cut cleanly if it cuts at all. I use a craftsman, never gets uncomfort.ably hot, just warm. I have a buddy who uses the B-D one, his doesnt overheat unless he cuts something too dense on a low speed. |
11-27-2005, 02:01 PM | #10 |
Yeah, run it fast but just fast enough, you don't need to spin the blade or cutter at 30,000 RPM to cut most things I don't think I've ever used more than half of what's available with my dremel
