06-14-2009, 02:12 PM | #1 |
Quarry Creeper Join Date: Nov 2006 Location: Longmont
| Homebrew Third Hand
I'm getting ready to braze up my first tube chassis and figured I'd need some extra hands to hold things in place, so I built some third hand tools out of stuff I had laying around. There was another how to post about this subject recently, but those were made out of plastic and would not have been useful for brazing. So here is what I came up with. Very easy to make the pics should explain it all. I used some heavy-duty alligator clips, 1/4" shaft collars, heavy gauge solid copper wire, and some scrap metal. Make sure to strip all the insulation off of the copper wire. The shaft collars make a strong heat proof connection for the alligator clip. Last edited by toybuilder; 06-15-2009 at 02:49 PM. |
06-14-2009, 04:36 PM | #2 |
Mmmmmmm.......Homebrew! :-P Cool idea.....I'm going to make up a set of these too. |
06-15-2009, 09:09 AM | #3 |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
| I love it! Making one today except I will just solder my clips to the wire |
06-15-2009, 09:17 AM | #4 |
If you solder the clips on, they will probably come unsoldered as you heat up the tubing.
06-15-2009, 09:42 AM | #5 |
| Yes. I tried it that way first, I had to scrounge up the shaft collars after the soldered clip fell off. It takes a lot less heat to solder the clip to the wire than it does to braze brakeline. Soldering it on may work if you are careful about where you clamp your work piece and where you direct the heat while brazing, but the shaft collar is fool proof.
06-15-2009, 09:43 AM | #6 |
06-15-2009, 11:25 AM | #7 |
RCC Addict Join Date: Apr 2009 Location: United States of the Offended
06-15-2009, 02:46 PM | #8 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
06-15-2009, 04:38 PM | #9 |
Pebble Pounder Join Date: Feb 2009 Location: LeMars, Iowa
Was thinking of doing something very similar but using some cheapie flat magnets with holes in the center from Harbor Freight as a base for each "hand". Granted, I have a metal desk top. Could not decide on how to make the "hands" bend and conform, looks like you solved that mystery for me. |
06-15-2009, 06:59 PM | #10 |
Newbie Join Date: May 2009 Location: westchester county
Love the wire idea!! I guess I'll be lookin for some wire tomorrow Thanks for the idea. Phil |
06-15-2009, 11:47 PM | #11 |
Quarry Creeper Join Date: May 2009 Location: sooke bc
i might half 2 make 1 now. good work
06-18-2009, 10:16 PM | #12 |
Pebble Pounder Join Date: Aug 2008 Location: Living in Paradise
Now that is slick, I need one for doing Deans Soldering. Thanks for the pics and writeup!
06-19-2009, 07:05 AM | #13 |
RCC Addict Join Date: Feb 2008 Location: your back yard
Thanks for this tip. I picked up some copper wire yesterday from a house we are doing and will be getting everything else I need from the LHS today. This will really help with soldering deans and on my first tube chassis..
06-22-2009, 08:29 PM | #14 |
| Got mine done!!
I got mine made finally......they are a bit long but I figured I could always trim them down. I also need to add some weight to the base....this was all I had in the shop. I plan to fill the bottoms with lead so that they will be a bit more stable. Thanks again Clint......great idea |
06-22-2009, 09:13 PM | #15 | |
02-25-2011, 09:31 AM | #16 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
braze the clips to the copper wire not solder them ..........bob .... |
02-25-2011, 09:43 AM | #17 |
Quarry Creeper Join Date: Aug 2009 Location: here
Get the clip too hot and you'll ruin the springs inside. I killed two so far building my tuber. I like the collar better for the fact that it's easier to replace the clips
02-25-2011, 09:56 AM | #18 |
02-25-2011, 10:37 AM | #19 | |
RCC Addict Join Date: May 2008 Location: Green Bay
02-25-2011, 12:02 PM | #20 |
