11-03-2005, 09:32 AM | #1 |
Quarry Creeper Join Date: Oct 2005 Location: MD
| Online Tubing
Building a Scale FJ40 Tube-on-Frame TLT (i.e. The frame will resemble a stock truck frame with tubing for exo, bumpers, shock hoops/mounts, axle trusses) The square/rectangle tube for the frame, I can source at Home Depot, no issues there. The tubing for the rest of the materials I need to order online since I am having trouble sourcing locally, and my work hours don't make it easy to get to a store during the week. Looking at the following tube from Mcmaster: Metric Carbon Steel Seamless Tubing OD: 6mm = .236" (between 3/16" and 1/4") ID: 4mm = .157" Wall: 1mm = .039" $12.95 for 6 ft I don't see any issues here, correct? Seems to be the most economical solution. Material will be mig-welded or brazed. Last edited by CronusTRD; 11-03-2005 at 09:48 AM. |
11-03-2005, 12:09 PM | #2 |
Quarry Creeper Join Date: Jun 2005 Location: Maryland
Any reason you dont want to use brakeline tubing. It is what is most commonly used. Cheap and available. It can be mig'd relatively easily. Cant wait to see it. |
11-03-2005, 12:54 PM | #3 |
| Trying something different. I heard issues with burn through with the mig with brake line. Seems this tube might work a little easier. It is a little thicker. I think typical brake line is .035" thick. I'm not doing a build thread, but will document and post it all at the end. I got some ideas brewing. It's nice to be back into this hobby. I have a large chest filled with nothing but losi/kyosho/associated parts. I should buy stock in Tower Hobbies with the amount of crap I've ordered. Last edited by CronusTRD; 11-03-2005 at 12:56 PM. |
11-03-2005, 04:46 PM | #4 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
9220K32 This tubing is cheaper and has a thicker wall. |
11-03-2005, 05:15 PM | #5 |
Diameter is too thick. I'm trying to stick with 3/16", 1/8" solid rod, and the 6mm metric. The 6mm metric will be for main supports, 3/16" for support, and 1/8" solid rod for the decorative crap. |
