11-02-2009, 09:24 AM | #1 |
Rock Stacker Join Date: Mar 2008 Location: in my room
| where do you get safety silver
is this something to get from a welding supply shop? And what do I ask for? Thanks
11-02-2009, 12:13 PM | #2 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
Welding supply stores will have it. Safety Silv is the product name Harris uses. Any high silver content solder for brazing will work though. Just tell them you're brazing steel together. Make sure to get flux with it.
11-02-2009, 12:19 PM | #3 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
I get mine at a welding supply store, but you can find it online. Ask for Harris Safety Silv 45 or 56. The 45 is a little cheaper and works just as good. Make sure you get the right Harris flux as well. A 1oz. roll of the 45 is about $18 but it goes a long ways.
11-02-2009, 10:43 PM | #4 |
Newbie Join Date: Oct 2009 Location: West Monroe
You can go to lowes or home depot and get brazing rods that are already flux coated.
11-03-2009, 04:10 PM | #5 |
Is the difference between 45 and 55 the silver content? Or a number to go with a melting temp? And can you use like a mapp gas or do I need to use oxy/axy set-up? And thanks for the help.
11-03-2009, 06:24 PM | #6 |
Pebble Pounder Join Date: Nov 2005 Location: Back in MICHIGAN
you can use a mapp gas, not sure on the difference between the two numbers are for though.
11-04-2009, 07:15 AM | #7 | ||
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
MAPP can be used, but IMO it takes too long to heat, and the torch tips are too big. But for builders on a budget it is cheap, easily attainable and it will do the job. I prefer an oxy/acetelyne rig, I can use the smallest brazing tip I have and get fast heat in a small concentrated area. One advantage of MAPP is you won't accidentally burn holes in your tubing if you let it get too hot, like you can easily with oxy/acetelyne if you don't pay attention... Last edited by Big Mike; 11-04-2009 at 07:18 AM. | ||
11-04-2009, 04:52 PM | #8 |
Thanks I am learning alot and am sure will put it to good use. Thanks
