11-06-2009, 08:25 PM | #1 |
Newbie Join Date: Jan 2009 Location: minneapolis
| tube frame
planning on building a sandrail chassis for my rusty and i was wondering wold brass tubing be ok? im just planing on using a micro or mini butane torch to solder.(downside of a condo) |
11-06-2009, 08:42 PM | #2 |
Rock Crawler Join Date: Sep 2009 Location: In West Monroe,LA...yes,where Duck Dynasty is filmed
actually 3/16 brake line tubing would be better.I also use 1/8 brass rods from home depot,eventhough you live in a condo you dont need much room as a mapp gas torch gets hot but not retina burning hot.Check out my sandrail in non crawler rc under krazykrawlers sandrail
11-06-2009, 08:47 PM | #3 | |
11-06-2009, 08:49 PM | #4 | |
thats a bad a** rail | |
11-06-2009, 08:56 PM | #5 |
thanks for kind words .once you practice a little it gets ALOT easier ,trust me you will be able to braze in your sleep.Im also working on a two seater sandrail and a tube frame baja truck.Set your mind to it and u can do anything .Good luck
11-06-2009, 09:03 PM | #6 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
