11-20-2009, 07:20 PM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: Indianapolis, IN
| MAPP Torch Help
I'm attempting to make a front bumper out of aluminum. I'm trying to use Dura-Fix and the propane torch I was using wasn't providing the heat I needed. I bought a MAPP torch which can be used with just MAPP or a MAPP/O2 mix. I tried to use this new torch and it is turning everything black. I followed the instructions that came with the torch so I don't know what the problem is. Anyone know what I might be doing wrong? |
11-20-2009, 08:10 PM | #2 |
Newbie Join Date: Nov 2008 Location: Canada
Dont quote me on this, but i dont think you can cut alluminum with a cutting torch. As far as i know they are only for iron / steel |
11-20-2009, 08:42 PM | #3 |
Thanks but I'm not trying to cut it I'm trying to weld/braze or whatever you'd call it with the Dura-Fix product. I basically just need to get it hot enough and the MAPP should do it, I just don't know how to keep it from turning everything black.
11-20-2009, 09:11 PM | #4 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
I tried that, but didn't think it got the aluminum hot enough...maybe I didn't leave it on long enough. how about keeping it black, then when your done use a wire wheel on a grinder and take off all the black? got a pic of what you doing...did it braze it??? maybe I should of stayed with it longer..might of worked huh??? |
11-20-2009, 09:14 PM | #5 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
You'll get the black soot using just mapp, use mapp and oxy, if/when you have the flame adjusted right it won't produce that soot, and should get plenty hot.
11-20-2009, 09:28 PM | #6 |
how do you adjust the flame...mine is just a torch with a ignitor..
11-20-2009, 09:31 PM | #7 |
I've never had any luck brazing aluminum. It just won't stick together. And btw, the Mapp will get it hot enough to melt, which pretty much ruins the part. |
