11-23-2009, 02:12 PM | #1 |
| Making a custom alumminum tuber
I have a few questions, i want to build a alumminum tuber, i was recommended to silver solder everything, but i know they make stuff to weld alluminum, so what should i do there, also should i cut out all the links individually or bend as much as i can,
11-23-2009, 02:22 PM | #2 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
Silver solder wont work with aluminum... There is a product called Durafix ( or something like that)... It uses aluminum rods, and you use a MAPP torch to braze with it. For your other question, If you have a way to bend the rod( whether it be a vice, bender, hands.. whatever you can find) I would bend as much as you can... it gives the chassis a more realistic look.
11-23-2009, 03:37 PM | #3 |
that durafix looks like it might work, does anyone have any experiences with it
11-23-2009, 06:16 PM | #4 |
i looked around and heard to use zinc flux and zinc solder, and it sticks to aluminum would this hold it together with a strong bond, or is the durafix still the best solution
11-24-2009, 09:35 PM | #5 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
12-08-2009, 06:43 PM | #6 |
Rock Stacker Join Date: Jan 2009 Location: La Vergne
The alumiweld stuff is what I have seen at Harbor feight. Going to pick some up and try it out. I will let everyone know.
12-08-2009, 07:17 PM | #7 |
Rock Stacker Join Date: Aug 2004 Location: Under a Rock
I've welded Alum for years, but how do you bend alum without it stressing and ripping on the outside of the bend ? Like in tight bends of say the stinger or shock hoops ?
12-08-2009, 07:25 PM | #8 | |
12-09-2009, 05:01 PM | #9 | |
Also anyone know about how much material it would take to make one would it be more than 6 feet | |
12-09-2009, 05:05 PM | #10 |
Quarry Creeper Join Date: Jan 2009 Location: North Wales, UK.
Hard to say how much you need, you'll have to allow for mistakes and how detailed your Tuber is. 6 feet would be a good guess...I guess! |
12-09-2009, 06:42 PM | #11 |
12-10-2009, 06:45 AM | #12 |
TIG is best, but have a look on YouTube for Durafix. Ive built a few tube chassis with it using Mapp gas. Tricky but once you get the hang of it...it's good stuff. http://www.youtube.com/results?searc...q=1&oq=DURAFIX |
12-10-2009, 09:24 AM | #13 | |
Here's a size picture to give you an idea of how much material I used. | |
12-10-2009, 10:38 AM | #14 |
What alloy of alum are you using ?
12-10-2009, 10:46 AM | #15 |
| 6061-T6 Solid 1/4". That's why I can get the tight bends that I do. It's easy to work with, and it's strong. Also mills, drills and taps nice but if you are welding that wouldn't matter. http://www.rccrawler.com/forum/showp...&postcount=106 |
12-10-2009, 10:54 AM | #16 |
How heavy do they end up ? Would the heavy walled tube work ? Say 1/4" O.D. by 1/8" I.D. ? Thank you for this info, I will be ordering up 20' of it right after Christmas... P.S. I just looked and my alum filler rod is 4043 |
12-10-2009, 11:00 AM | #17 | |
12-10-2009, 11:04 AM | #18 |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
if your want tighter bends with 6061 T6, heat it up first then bend it. works every time & i getting some super tight bends that way. the DmG custom Alum tube chassis |
12-10-2009, 11:05 AM | #19 |
I have a Pro-Line Nylon tuber.......... LOVE it as it keeps the weight low. But I LOVE a metal as its more realistic, a rig needs some weight to it to make it act a little more realistic ya know... I'm no comp guy, or even a "rockcrawler" but a do it all trail rig. 8lbs total isnt so bad.... gear it down and volt it up ! Again thank you for the info.. |
12-10-2009, 08:20 PM | #20 | |
