11-23-2009, 05:19 PM | #1 |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
| Can you bend Delrin?
I was thinking maybe with a heat gun? Will it work? I have some 5/16 rod and I'd like to curve my links. Sorta like high clearance links.
11-23-2009, 06:50 PM | #2 |
Rock Crawler Join Date: May 2007 Location: lacey
seen it done, not sure how. heat gun sounds good.
11-23-2009, 06:55 PM | #3 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
I use a HEAT GUN......in a pinch I will use a butane mini torch.
11-23-2009, 07:26 PM | #4 |
Pebble Pounder Join Date: May 2009 Location: South Gap
Use a heat gun if possible.. ive melted delrin using a torch.. but can be done if careful.
11-23-2009, 07:47 PM | #5 |
Quarry Creeper Join Date: Mar 2009 Location: vacaville
I used to run 5/16 bent links and they flex way to much. In some cases it worked in my favor but mostly unpredictable.
11-24-2009, 12:12 AM | #6 |
Quarry Creeper Join Date: Sep 2009 Location: Concord
try boiling them then put them in a jig
11-24-2009, 06:17 AM | #7 |
Thanks for all the advice guys. I will be going up to the shop tonight to do some experimenting. I have a adjustable heat gun, it can melt pvc no problem if you aren't careful. It should do the trick I think. I will try to make a jig so they all come out the same. ncalkrawler, when you found the 5/16 flexing, did you go to 3/8? That just seem'd too big for 1/10 scale.
11-24-2009, 06:33 AM | #8 | |
I make/sell a mixed material type of link. 1/4 Delrin sleeved over 4mm threaded steel rod. I then heat & bend it in a jig. It is VERY strong...no bending. Some guys like a little bend in their links...some like a VERY rigid link. I cater to that design choice. One small word of advice....if you are heating delrin, use good ventilation. | |
11-24-2009, 07:34 AM | #9 |
Pebble Pounder Join Date: May 2007 Location: No Where
I formerly worked at a plastics shop and we did not bend delrin. I was told it was because it was a thermoset and not a thermoplastic. So i wanted to chime in on this discussion I typed up this long reply stating you cannot bend delrin. After the post I did a little research and found out that Delrin is in fact a thermoplastic. Direct from Dupont's own website. Its melting point is 347F. Next i deleted my post and replaced it with this more informative one, enjoy. So yes you can and good luck. I would make sure to test on a few scraps first. Last edited by King of Beers; 11-24-2009 at 07:41 AM. |
11-24-2009, 12:12 PM | #10 |
Rock Stacker Join Date: Oct 2009 Location: YORK
11-24-2009, 12:24 PM | #11 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
11-24-2009, 12:36 PM | #12 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
I bent some 3/16 delrin with a lighter, worked really well. sanded it and you could never tell I did it by hand. |
11-24-2009, 01:27 PM | #13 |
11-24-2009, 01:54 PM | #14 |
Since I put metal thru the middle of mine, I only have to heat it moderately...then bend....the steel holds the position while it cools.
11-24-2009, 03:11 PM | #15 | |
I'm not going to my shop tonight, so I have some extra time to think about this. I was thinking just curved links this time without rod all the way through. Save that for the next set. I like to experiment. I was going to heat up short lengths with the heat gun, on a curved piece of metal. If they're side by side, when they cool, they should all have the same arch. Thanks for all the thoughts and advice. | |
11-24-2009, 03:24 PM | #16 | |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
Thanks for the props Tom. My links are made with 3/8" solid rod. The method that I use is a heat gun and a composite tubing bender. I only heat the rod where I want the bend and never overheat. Rotating the rod while applying heat. Remove the heat when you just start to see the rod getting shiny. Again don't overheat. Next I quickly insert it in the bender and bend well past desired degree, example, for a 30* bend I'll bend the rod to almost 90* and then apply a little more heat. Once again do not overheat. Remove heat and let cool for a few seconds, still holding the bend, then release and adjust to desired degree. I use a aluminum 30* link to get it close, it stays pliable for a little while so it can be adjusted, then install my rod ends and check for the correct length. Once I'm happy with the first one, I use it as a guide for the rest. That's what works best for me, I've made hundreds of links now and have no complaints or failure to date. What ever method that you decide to use, just take your time and don't overheat, it should never be a wet noodle. Quote:
11-24-2009, 03:37 PM | #17 |
Hey Shon,,you set the mark i just pass on what i know
11-24-2009, 04:35 PM | #18 | |
11-25-2009, 06:24 AM | #19 | |
i dont think so, i used that same method that you described. it wasnt bad while i was in the room but i left the house and came back and thats when i noticed it | |
11-25-2009, 06:33 AM | #20 |
Hence why I do the cutting/heating in the garage...with the door open. But if you really limit the heat, the smell is dramatically less. My wife is super sensitive to smells....and she does not complain about the delrin.
