12-20-2005, 05:42 PM | #1 |
Quarry Creeper Join Date: May 2004 Location: stuck in a damm jar
| tube wall thickness, what brazing rod to use and how much
Well, I was wondering what you guys suggest for tubing thickness on 1/4 in tube and 3/16 tube. Also I was wondering what brazing rod you use and how quick you go through like how many ounces to the frame safty-Silv56 is kinda pricey |
12-20-2005, 06:56 PM | #2 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
and safety silv is the best way to go... use the safety silv 56 or 45( I use 45) and the matching white flux.. it is a bit more, but welllllllllllllllllllllllllll worth it. I buy a 5 troy ounce of the safety silv 45 and it runs me like $40 and the flux is like $5 from my local welding shop.. 1 troy ounce is like $15. I use it on 1/4" brakeline,3/16" brakeline, same sizes but solid rod, etc.etc. and it all holds. You just have to add different heat ( more or less) depending on what size/thickness your using Last edited by TwistedCreations; 12-20-2005 at 06:58 PM. |
12-20-2005, 07:21 PM | #3 | |
Rock Crawler Join Date: Dec 2004 Location: Land of the Free, because of the Brave
This is probably one of the smallest quantities of rod/flux you can buy, and it will keep you building tubers for months, maybe years. -WRM | |
12-20-2005, 07:51 PM | #4 |
Thanks for the compliment Rich you can see the flux in this pic ( you can see the rod off to the right also) and you can see the brazing rod in the next pic. That is what you want and need Everyone calls it brazing rod, but it actually isn't like a brazing rod you pick up at home depot. The stuff you get at home depot,lowes,etc. is for bigger stuff. It has a higher melting point before it starts to melt, but by that time, you done melted holes in your project or melted it away. the rod in the pic is from a 5 troy ounce roll. I have built 2 tubers and axles with the same roll. if you are just starting out, you may use a bit more to get used to it. But once you get the hang of it, it is cake work. again, well worth the extra money |
