12-14-2009, 05:30 PM | #1 |
Quarry Creeper Join Date: Apr 2005 Location: Malaysia
| Countersinks - what to look for
I'm looking for some 90 degree and 82 degree countersinks to add to my tool collection. Mainly will be countersinking 3mm screw holes in aluminium RC car parts, but occasionally will use them on free machining steel. What kind of countersinks should I be looking for. I seem to see a whole variety on ebay and some of them are really cheap. Also, they need to fit a collet or will a drill chuck do? Thanks in advance. |
12-14-2009, 06:11 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I'm not sure about brands off the top of my head. But, I personally prefer the single flute c-sinks, they pull a nice smooth chip in most soft metals. Multi-flute c-sinks can have a tendency to chatter, unless you have the ability to run at really slow RPM's. Either one will work in a drill chuck just fine. |
12-14-2009, 06:47 PM | #3 | |
Most people do not have a mill handy, or a way to properly locate and secure their work, and that is where I would grab a multi-flute, but again Bender is totally correct......SLOW IT DOWN!!! We have so many people come into the shop, chuck up a multi-flute countersink and spin it like a drill bit........Chatter City! Basically if you can't see each flute go by as it spins, you are turning it too fast. . Last edited by C*H*U*D; 12-14-2009 at 07:09 PM. | |
12-14-2009, 08:26 PM | #4 |
Pebble Pounder Join Date: Dec 2008 Location: Tomball, Tx
i prefer to use a multiflute for hand work. have a carbide 3/8 on a handle for smaller work. Consider carbide if you think you might do some carbon fiber. a HSS c-sink might last for 2 rotations in cf. carbide is hard as hell and as brittle as moms fine china. keep it in a box or case or protected in some way. m.a.ford (i think) is a good brand. be prepared for some sticker shock, but if well taken care of, you will only have to buy it once.
12-14-2009, 09:10 PM | #5 | |
Quarry Creeper Join Date: Oct 2008 Location: Oakley
Get the 82 degree for metric and English flat head screws, 90 degree are for aircraft flat head fasteners. As has been stated by others, single flute work really well, do not run at a fast speed unless your material is secure. Works well with hand drill or drill press. and I agree, multi flute will have a tendency to chatter unless run SLOW. P.S. Buy a good High speed steel, they will last a very long time and therefore cheap in the long run. Last edited by CadToChrome; 12-14-2009 at 09:14 PM. Reason: added to post | |
12-14-2009, 10:29 PM | #6 |
RCC Addict Join Date: Mar 2008 Location: SSF
Manufacturer's name; Ford single flute Severance multi-flute These are the only CS's I buy in this configuration. Severance single flute are marginally good and Ford multis' are crap. I should add that Severance carbide single flutes are really good, unlike their HSS. |
12-15-2009, 04:54 AM | #7 |
Pebble Pounder Join Date: Sep 2009 Location: The Land of Ahhhhs
I can't speak from a machinist's point of view, so these guys prolly know more than I do. But, from a sheet metal mechanic's perspective, I prefer the brand "Weldon". They are single flute and I've used them on everything from O condition aluminum to inconel and they work great. 1/4" shank on the three most common sizes so they can be used in a collett or in a chuck. If you want something to use in a microstop, you'll have to find some that are threaded. Try looking here www.yardstore.com |
12-15-2009, 10:08 PM | #8 |
Thanks for all the help guys. I just paid for a 90 degree 3/8" single flute HSS M.A. Ford on ebay. Now for the 82 degree. Might settle for 1/4" if I can't get bigger. |
12-16-2009, 08:33 AM | #9 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
This is a good option from Irwin Tools. http://teamscreamracing.com/catagory...es_and_Springs |
12-26-2009, 01:18 PM | #10 | |
Rock Stacker Join Date: Jan 2008 Location: Laval
- Are you planning of just cleaning countersinks or making new ones? - In what type of material? - By hand or by drill? - What diameter fastener do you need it for? Either way, I would suggest getting a 3-4 lip carbide with a 1/4 straight shank. So you can use it either by hand (for cleaning existing countersink only) in a tap wrench or in a drill chuck. Should run you about $15-$20 for the countersink that's made for 3mm-5mm fasteners. Hope this helps | |
12-26-2009, 01:33 PM | #11 | |
If you have a drill press and a vise, you can get decent results with a single flute c-sink. A small spray of cutting oil never hurts, either. | |
12-26-2009, 02:18 PM | #12 |
Quarry Creeper Join Date: Apr 2009 Location: Lincoln
I use my M.A. Ford six flute countersinks everyday at work. MA is the best in my opinion, both single and six flute.
12-26-2009, 02:28 PM | #13 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
For what its worth I use the cheapo Harbor freight countersinks in my cordless drill. Good enough for me. Works better then attempting to use a oversize drill bit. |
12-27-2009, 09:38 AM | #14 | |
01-05-2010, 11:50 AM | #15 |
Rock Stacker Join Date: Oct 2009 Location: Canada
Single flute work nicely with no chatter. Cant remember where I bought mine but they werent expensive ones.
