12-16-2009, 09:04 PM | #1 |
| mini chop saws?
Looking for a smaller chop saw I can cut smaller steel stock on. Anything you guys recommend? |
12-16-2009, 10:25 PM | #2 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
If you own a 4" grinder, i saw one that you mount your grinder in for about 30.00 i belive it was at harbr freight... |
12-16-2009, 10:29 PM | #3 |
Hateraide Join Date: Dec 2008 Location: Mission BC
the ones for the grinders work great ive used them before , thats if you have a grinder
12-16-2009, 10:39 PM | #4 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
harbor freight has a proxxon knock off, and micromark has a rebadge proxxon, if you have the $$$ buy a proxxon, you wont be sorry,but I dont care for "chopsaws" way to much mess and noise, I went with a proxxon mini bandsaw and so glad I did, I can cut everything a chopsaw can, plus I can do curves and such,material stays cooler, since your cutting not grinding, plus if you buy or make a wet cutting kit for the bandsaw, no more dust, which allows you to cut cf or fg with no flying dust, plastic does not warp or bind in a wet cutting setup, I blast thru 18 ga, stainless like I am cutting cardboard, once you get the right blade, you'll wonder how you ever lived without one.
12-16-2009, 10:59 PM | #5 |
Say hello to my dactylion Join Date: Jun 2004 Location: On the Boat to Whore Island
This is the one Kaetwo, Just Zach & I use.... it works great and it is cheap. Loud as hell though. http://www.harborfreight.com/cpi/cta...emnumber=41453 |
12-16-2009, 11:49 PM | #6 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
here is one I have used,works good IMO...Easy to get locally for most. http://www.sears.com/shc/s/p_10153_12605_00926850000P |
12-17-2009, 02:13 AM | #7 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
I have the $39.99 harbor freight saw and it works great
12-17-2009, 06:27 AM | #8 |
Thanks guys, I have a craftsman bandsaw that is great for cutting aluminum, but it kills blades anytime I even think about steel. Was thinking a chopsaw was a good alternative. I hate cutting with my dremel. |
12-17-2009, 06:33 AM | #9 |
Rock Crawler Join Date: Dec 2005 Location: Huntertown, In
I use a modified chainsaw sharpener, it sat at an angle and I just modified one bracket and now it sits perfectly straight.
12-17-2009, 10:26 AM | #10 | |
probandsawworks.com is where I got my blades made, they are freaking awesome and pretty cheap, I got 3 custom blades made and shipped for $51,$10 was for shipping, so it works out to $13 and some change for each blade. The only major plus about a chop saw is material length can be anything, your limited by the throat of a bandsaw, but I never had a issue really, though I do own 3 different metal cutting bandsaws proxxon makita lxt Jet 5x6 | |
12-17-2009, 11:05 AM | #11 |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
This one is the best for the money! Had mine for 11+ years and still going! http://www.harborfreight.com/cpi/cta...emnumber=42307 Last edited by KRAWLR4life; 12-17-2009 at 11:08 AM. |
12-17-2009, 04:06 PM | #12 | |
I will check that out. | |
12-17-2009, 05:46 PM | #13 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
Ive got the HF one... the stock blade is awesome for cutting light material and is the best tool for cutting delrin rod. They also make an abrasive wheel that works great for cutting metal. (and they are currently on sale for $25)
12-17-2009, 05:53 PM | #14 |
| Ive seen that little HF one at the local store, but could not for the life of me find a abrasive wheel that fit..
12-17-2009, 11:12 PM | #15 | |
Variable speed a + but 2 speed min bimetal blades aval locally or sold at retailers wet cutting able - a must for cf/fg/stainless,alum, hell just about anything around 300 So the proxxon fit the bill, as proxxon themselfs but wanted $21 a blade plus it was special order thru my proxxon dealer-fuken hawaii sucks they dont stock shet even the saw was special order and cost just as much as my jet 5x6 -, then I was looking around for some bimetals for my jet, since the guy I use to go thru dropped off the face of the earth ,$10shipped for 64 1/2 bimetals is a freaking deal, checked and checked everyone else was gonna rip me on shipping + the custom blades, found probandsaw made my order and it was well worth the try. | |
12-18-2009, 03:17 PM | #16 | |
Rock Stacker Join Date: Nov 2006 Location: 1/2 way between Cleveland and Columbus
http://www.harborfreight.com/cpi/cta...emnumber=44812 These will fit, but you have to remove the guard. Guards are for people who don't know how to use tools anyways. Or, if you want to keep the guard you can get a 2" diameter 3/8" arbor disk here. http://www.mcmaster.com/#cutoff-wheels/=4znhkq Last edited by NeoNeoN; 12-18-2009 at 03:20 PM. | |
12-19-2009, 10:09 AM | #17 |
Quarry Creeper Join Date: Nov 2006 Location: Longmont
I use this stand from Grizzly with my 4-1/2" angle grinder: http://grizzly.com/products/4-1-2-An...er-Stand/G8183 Cheap and works great. |
12-19-2009, 01:45 PM | #18 | |
Pebble Pounder Join Date: Dec 2009 Location: Lancaster
12-19-2009, 02:10 PM | #19 | |
It definately takes awhile to cut anything, but the size is nice for brake line. You don't handle the line as much, so there is less chance of bending it. | |
12-19-2009, 04:03 PM | #20 |
RCC Addict Join Date: Mar 2007 Location: MS Gulf Coast
Thanks for the info guys! I've been thinking about one of these lately since I've just recently started brazing and working with small materials. Been using a dremel and handsaw but dremel isn't accurate and the handsaw, well lets face it I'm lazy! |
