12-19-2009, 11:07 PM | #1 |
Rock Stacker Join Date: Sep 2007 Location: australia
| tuber/roll cage q
hey so when making a bumper, roll cage or tuber chassis i want to use brass so do i use rod or tube as tube will crush on rolls? or solid is more rigid or is it ok as tube? thanks! |
12-20-2009, 12:33 AM | #2 |
Pebble Pounder Join Date: Dec 2009 Location: Lancaster
Solid is heavy, my first tuber im making now is 3/16 brake line, make sure you clean it and remove the galv before you weld. I use a torch and lincoln electric welding rods, brass rods flux coated.
12-20-2009, 05:23 PM | #3 |
RCC Addict Join Date: Sep 2007 Location: Hallsville, Tx
he is talking about brass not brake line. brass is strong in a solid rod but i would think the tube would be too soft. it is cheaper to use stainless brake line.
12-20-2009, 06:19 PM | #4 |
^ ok thanks, i like your sig ;) how do you braze aliminum 1/4 tube? or will that be too weak also? what size brakeline do i et and should i order it from repco and other auto shops we have (btw, my dads a mechanic so i get trade price hehehe) |
12-20-2009, 10:09 PM | #5 |
Sorry I mis read you were talking about using brass to make the bumper... Id probably still go with the steel brake line, 3/16 is a good size, depending on scale ive seen some guys use 1/8th" rod, even 1/4" brake line. On a nasty fall you can bend anything reguardless of the material. Brakeline is just pretty cheap and they sell it at pretty much any auto part store.
12-21-2009, 04:21 AM | #6 |
yeah i will use 1/4 brake line, i also just tried bending a little tube i found on a prado fuel tank left out for srcap, with pliers and and vice, pipe kinks flat but get a spring and slide it over do the same and u get a real nice, round bend for those who dont know haha
12-27-2009, 10:35 AM | #7 |
Rock Stacker Join Date: Sep 2005 Location: lakeland
u can also get brake line benders from the auto parts store they dont make super tight bends but they get the job done.
12-27-2009, 12:06 PM | #8 |
RCC Addict Join Date: Jan 2007 Location: caldwell,idaho
i use 1/8 " rod or 3/16ths rod it is cheap and strong and easy to braze brakeline is about 7 bucks for 5 feet and it kinks if you don't use a bender with the rod i can bend it by hand or stick it in the vise and bend it by hand and get really tight bends i can do a 90 degree bend with no problem a 20 foot section will cost me about 4 bucks.1/4 inch rod or tube looks too big.
01-03-2010, 11:09 PM | #9 |
Rock Stacker Join Date: Apr 2009 Location: canada
does anyone know where someone can buy it in a bulk the local store here sells it 1 m for 9 dollers and can you tell me where u can get plans on different custom tube frames that can be copyed thanks
03-31-2010, 12:41 AM | #10 |
Rock Stacker Join Date: Apr 2009 Location: Slovakia
the problem is, that i was told in our country steel brake line is not saled at all. only brass. so my question was the same - is the brass frame strong enough for truggy cage, sliders, bumpers..? my idea was that structure makes it solid.. as i understand - its also easier to braze brass than steel. as i can have only small micro butane torch setup doing it inside small room. Last edited by matador88; 03-31-2010 at 11:45 PM. |
03-31-2010, 09:40 PM | #11 | |
Rock Stacker Join Date: Dec 2009 Location: Clemson
For brazing brass, make sure the rod has a low melting point (well below ~920*C, preferably closer to 500-600*C). Your butane torch should do fine. | |
